Any recommendations for tube for vari-mu compressor?
Old 8th April 2009, 04:45 AM   #1
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Default Any recommendations for tube for vari-mu compressor?
Looking for a cheap tube to try for the front tube in a vari-mu compressor for a guitar amp, not a studio. I've already done a bunch of research:
Vintage tube compressors use the $$$ 6386 tube. I think a triode strapped 6BA6 is what is generally considered the best sub for that; it's even sold on the Manley Labs site. Yet on Fred Nachbaur's site he slammed the 6BA6 as often microphonic, and said the 6BJ6 is better. He used the 6JB6 in the Li'l 4x4 amp, and a 6K7 in the Dogzilla amp. There is also PRR's DIY vari-mu compressor which uses the 12AU7, but this design supposedly runs out of steam and can't deal with higher compression rates.
In any case, I'm looking for either a specific recommendation on a tube for this app, or at least a recommendation for a (very) remote cutoff pentode to try.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 8th April 2009, 05:08 AM   #2
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
6BA6 and 6K7 are "very" remote tubes, both 6BJ6 and 6J7 are less remote pentodes.
The Devil is not so terrible as his math model is!
Old 8th April 2009, 02:28 PM   #3
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
Wasn't JJ going to make a 6386? I don't see it for sale anywhere, though. I have sales literature for it.
Old 8th April 2009, 03:50 PM   #4
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Check this thread:
http://www.diyaudio.com/forums/showt...315#post951315
Don
Old 8th April 2009, 08:14 PM   #5
leadbelly's Avatar
Originally posted by smoking-amp
Check this thread:
Ah! I assume you mean using the 6BN6 as a "roll your own cutoff"? Sounds a bit challenging, but possibly VERY rewarding. The references to "accelerator", "limiter", and "quadrature" are somewhat intimidating. To dumb it down a bit, is there something wrong with a starting point of strapping g2 to the plate, and biasing g3 positive with a zener between it and the plate?
EDIT: thinking about it some more, couldn't you bias g3 to the point where it becomes a vari-mu expander?
Old 8th April 2009, 08:23 PM   #6
"Ah! I assume you mean using the 6BN6 as a "roll your own cutoff"?"
6BN6 looks complicated. But if you can figure it out....
I was thinking more along the dual control grid tubes. (You just put a control voltage proportional to signal envelope on g3 for compressor use. Or could just try direct biased up signal on g3 [and still g1] for some really potent distortion effects.)
Or, the many other remote cutoff tubes. George (Tubelab) mentioned the 6SK7 for instance, but there seem to be a bunch of others. 6SS7 for example. You need to rummage thru the GE Essential Characteristics book for them all.
Don
Any recommendations for tube for vari-mu compressor?Hide this!Advertise here!
Tube Compressor Ahmad_tbp Instruments and Amps 67 7th June 2014 08:42 AM
Input tube recommendations... SpreadSpectrum Tubes / Valves 9 15th January 2009 07:41 PM
Schematic for tube compressor/sustain ? whatsnext Instruments and Amps 6 23rd August 2005 04:52 PM
Tube compressor problem! coony Tubes / Valves 7 1st February 2005 08:08 AM
Tube Cooling Recommendations gingertube Tubes / Valves 20 21st December 2004 07:52 AM
Copyright ©1999-2017 diyAudio
