diyAudio Sponsor
Old 7th April 2009, 06:55 PM   #1
Default Rectifying Heater Supply
Hi, My heater supply is AC which is fine but I would like to use the same tap of the transformer to provide a rectified DC signal for channel switching etc.
I was going to rectify after the input valve at the end of the AC chain but unfortunately this is on the opposite end of the chassis to where I need it. Would it make any difference for better or for worse simply taking another two wires off the beginning of the chain which is attached to a filament lamp and rectifying there?
Old 7th April 2009, 07:18 PM   #2
HollowState's Avatar
Your idea seems fine to me. Taking some extra power from close to the source is the correct way of doing it anyway. A small bridge rectifier, or full wave depending on your configuration, and a single filter cap should serve well. Just remember common sense things like keeping AC wires away from signal lines and twisting them close to the chassis if there is length involved.
Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 7th April 2009, 07:35 PM   #3
Thanks for the clarification - makes things easier now!
Looking for 6.3V 1A ccs heater supply for dht martyh Tubes / Valves 9 8th June 2009 11:42 PM
dc heater supply help milen007 Tubes / Valves 17 21st February 2009 07:42 AM
Is this heater supply OK? Nuuk Tubes / Valves 39 18th August 2006 11:20 PM
help with heater supply jarthel Tubes / Valves 5 24th July 2003 01:12 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.07129 seconds (71.60% PHP - 28.40% MySQL) with 10 queries
