tube heater over voltage!please help... - diyAudio
Old 7th April 2009, 03:16 PM   #1
tubo is offline tubo  Philippines
Default tube heater over voltage!please help...
hi folks,
the heater voltage on my 6v6 amp reads 8.20vac.... i tried dropping resistors in series with one of the filament pins from .5ohm to 10ohm i still see no drop in voltage.....please help
thanks,
ivan
Old 7th April 2009, 03:27 PM   #2
Tom Bavis's Avatar
Are you measuring at the tube socket pins with tube in place? There's no voltage drop if there's no current...
Old 7th April 2009, 04:10 PM   #3
thanks tom....problem solved! im now reading 6.1 volts! is the tube underheated? does it really need to be 6.3v?
Old 7th April 2009, 06:59 PM   #4
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
6.1V is good enough.
Old 7th April 2009, 10:33 PM   #5
Absolutely- and your tubes will last quite a bit longer as well, with slightly lower heater voltage.
John
Old 8th April 2009, 11:37 AM   #6
thanks fellas! greatly appreciated!
God bless!
ivan
Old 8th April 2009, 11:58 AM   #7
nkg is offline nkg  Australia
Hi
Its also worth while having heater transformers custom wound with different taps on the primary. With nos valves becoming more expensive the cost is worth it .
nkg
DC Heater Voltage Bengali Tubes / Valves 9 2nd February 2009 04:19 AM
heater voltage Jaap Tubes / Valves 3 18th November 2008 11:39 PM
Too low heater voltage? jkeny Tubes / Valves 6 26th August 2008 12:08 AM
tube heater voltage, how much is too much? randytsuch Tubes / Valves 26 19th August 2008 02:42 AM
heater voltage of scope picture tube ? Bernhard Parts 1 18th September 2005 03:03 PM
Copyright 1999-2017 diyAudio
