GM-70 cathode feed SE amplifier
Old 6th April 2009, 11:43 AM   #11
Bandersnatch is offline Bandersnatch  United States
hey-Hey!!!,
Also add that the grid is now a screen, keeping the input away from effects of the output...no more Miller. However, a driver stage with reqired output Z to drive the cathode will not much mind the plate capacitance I suspect.
cheers,
Douglas
the Tnuctipun will return
Old 6th April 2009, 12:17 PM   #12
kavermei is offline kavermei  Belgium
kavermei's Avatar
Send a message via MSN to kavermei
Allen,
basically what Jan and Douglas are saying, most importantly the driver sees a constant load regardless of grid current.
Also (if I remember this correctly, anybody pls correct me otherwise...) grounded grid gives a slightly higher amplification factor compared to common cathode (1+mu vs. mu)
Finally the drive signal is in series with the load (OPT primary) so, other than the fact that the driver contributes directly to the output power, I'd guess this would have an effect on the sound too.
kavermei
Old 19th April 2009, 03:59 PM   #13
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign GM-70 cathode feed SE amplifier
This is my last test about GM70 performances
http://www.audiodesignguide.com/Clau...test_GM70.html
GM-70 cathode feed SE amplifierHide this!Advertise here!
20W cathode follower amplifier yan24 Tubes / Valves 137 6th September 2017 01:28 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
TCJ Cathode-Coupled Amplifier seventenths Tubes / Valves 3 18th July 2007 05:05 PM
hybrid common cathode amplifier? mwmitchell Tubes / Valves 19 16th January 2003 01:51 PM
