Question about current ratings of Hammond 300 series power transformers.
Old 2nd April 2009, 07:12 AM   #1
G is offline G  United States
G's Avatar
Default Question about current ratings of Hammond 300 series power transformers.
Hi all. If you had a circuit that required 85mA would you hesitate to use a Hammond power transformer rated for 100mA? Also, if the filaments of said circuit required 1.8A would you use the 2A winding on the same transformer? I don't want any problems in the future!
Gavin
Old 2nd April 2009, 07:27 AM   #2
Geek is offline Geek
Geek's Avatar
I would call that the "perfect match" transformer myself
Cheers!
Old 2nd April 2009, 07:40 AM   #3
G's Avatar
Cheers!
Cool! Last question. Is a 125-0-125v transformer considered a 250v center tapped transformer?
Gavin
Old 2nd April 2009, 09:00 AM   #4
Geek's Avatar
Yes, it is!
Sounds like you're building a little SE power amp or a preamp with 6-8 tubes?
Cheers!
Old 2nd April 2009, 02:41 PM   #5
G's Avatar
Yes, it is!
Cheers!
SE 12B4A amplifier. A 1.25 watt monster!
Gavin
Old 2nd April 2009, 08:41 PM   #6
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
If you mean 85mA ac measured from the transformer then that would be OK.
But if the 85mA is the current taken from the dc (rectified) supply then you'll need more like a 200mA rating. The value of the transformer current depends on the value of capacitance after the rectifier, and the whether it's choke or cap input architecture.
work out the current by using PSUD2:
http://www.duncanamps.com/psud2/index.html
this works near perfectly on Linux platforms (using the WINE environment) so you can dump that Conficker-riddled Windows and use DIY friendly OS
http://www.kubuntu.org/
Old 2nd April 2009, 09:30 PM   #7
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Hammond transformers are specified for DC current draw. From their web site:
"High voltage current is D.C. using C.T. Full Wave rectifier - capacitor input".
I am guessing that we are talking about a 369AXP which will make about 150 to 160 volts DC (just my guess) using solid state diodes and a capacitor input filter. There would be no problem drawing 100 mA from this supply. Even more could be drawn if you are running it on 60Hz since the 300 series is rated for 50Hz.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 3rd April 2009, 05:58 AM   #8
G's Avatar
Well I wanted to use this PSU:
http://www.welbornelabs.com/ps10.htm
but I can't find the right transformer for the job. I need a 360v-400v center tapped transformer that will supply at least 150mA. Any suggestions? Hammond does not make such a animal.
Gavin
Old 3rd April 2009, 06:02 AM   #9
G's Avatar
I suppose I could stick with a 5AR4 rectifier and use a Hammond 370FX. I'm assuming that the 5AR4 will drop some of the excess voltage. I would like for the regulator to run cool without having to drop too many watts to get to the target voltage of 215v.
Gavin
Old 3rd April 2009, 10:50 AM   #10
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Have you tried looking through the .pdf of all Edcor's power transformers? They might have something in there...
http://www.audiotransformers.net/for...hp?topic=198.0
The first one I see might be an XPWR105. It says it is good for 360 VCT at 250 mA, and 6.3V at 3 amps. There might be other candidates in the list too.
Question about current ratings of Hammond 300 series power transformers.Hide this!Advertise here!
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 10 3rd August 2012 07:32 AM
Hammond PT power ratings dsavitsk Tubes / Valves 4 23rd August 2009 08:23 PM
Question about Allied & Hammond Power Transformer Ratings Bitrex Tubes / Valves 2 6th March 2009 07:31 AM
Quality of Hammond 1600 series transformers and a question about loading. G Tubes / Valves 2 24th March 2008 12:31 PM
Two transformers in series, what happens to the ratings? Jeremy_Wolf Solid State 21 13th January 2002 06:13 PM
Copyright ©1999-2017 diyAudio
