diyAudio Sponsor
Old 3rd April 2009, 03:43 PM   #11
I would try others like Edcor.
Hammond's PT spec and actual numbers are not very close.
Old 3rd April 2009, 04:54 PM   #12
G is offline G  United States
G's Avatar
Originally posted by Ty_Bower
Have you tried looking through the .pdf of all Edcor's power transformers? They might have something in there...
http://www.audiotransformers.net/for...hp?topic=198.0
The first one I see might be an XPWR105. It says it is good for 360 VCT at 250 mA, and 6.3V at 3 amps. There might be other candidates in the list too.
Spot On! I just ordered the 105 and the 104. They are running about 3 weeks behind though but that is just fine. They look like really nice transformers and their specs are perfect for my new preamp/amp! I had forgotten about Edcor. Thank you. Bandersnatch is going to drool all over himself when I post pics of the 12B4a powerhouse amp I'm building.
Gavin
Old 4th April 2009, 12:12 AM   #13
Geek's Avatar
I found the current ratings OK, but voltages to be somewhat highish.
Example, I have a 279GX here rated 225-0-225 @ 65mA and 6.3V @ 2.5A. At full load she delivers 250-0-250 HV and 6.7V heater
Good to hear their business is picking up. They were 2 weeks behind last week
Cheers!
Old 4th April 2009, 05:32 AM   #14
mosfets is offline mosfets  Canada
Typical for Hammond at 60Hz. Tubelab has noted above. Depending on your application, I guess it could be a nuisance.
Old 4th April 2009, 06:38 AM   #15
Geek's Avatar
I should have read more closely
But yeah, it is a nuisance, as it meant extra and unanticipated regulator dissipation.
Cheers!
Hammond PT power ratings dsavitsk Tubes / Valves 4 23rd August 2009 09:23 PM
Question about Allied & Hammond Power Transformer Ratings Bitrex Tubes / Valves 2 6th March 2009 08:31 AM
Quality of Hammond 1600 series transformers and a question about loading. G Tubes / Valves 2 24th March 2008 01:31 PM
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 8 21st September 2003 03:27 PM
Two transformers in series, what happens to the ratings? Jeremy_Wolf Solid State 21 13th January 2002 07:13 PM
Page generated in 0.08865 seconds (74.25% PHP - 25.75% MySQL) with 10 queries
