diyAudio Sponsor
Old 2nd April 2009, 05:04 AM   #1
Default Cathode Windings
Hi ,
I salvaged a pair Fisher output transformers with tertiary windings to be used as cathode windings .The outputs are 4300k CT primary winding , 280 ohm CT tertiary primary winding and 16 , 8 ohm secondary at about 30 watts and is slightly larger than Dynaco ST 70 transfomers .I am wanting to use these with PP 5881 or 6CA7 in triode mode using the cathode windings .Will i have to stick with cathode bias or is a seperate bias supply practicle . Would a driver PCB such as a Posiden or Triode electronics MK4 have enough gain to drive the output using the cathode feedback windings .I'm open to driver curciut sugestions the only circuit i have found that use cathode windings like this is the Quad II and the Fisher model 80AZ .
http://www.ampslab.com/vintage_fisher80az.htm
Mark
To be better one must be different ,but to be different is not necessarily better .
Old 2nd April 2009, 05:30 PM   #2
Miles Prower's Avatar
Default Re: Cathode Windings
Originally posted by battradio
Will i have to stick with cathode bias or is a seperate bias supply practicle?
Fixed bias with that sort of cathode feedback is quite practical.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 3rd April 2009, 12:20 PM   #3
Default Re: Re: Cathode Windings
Yes it is. The DCR of each half provides a current sense resistance to determine idle current measurement. I have used just such an arrangement with Chicago output iron as well as the Dynaco A441 output TX's.
cheers,
Douglas
the Tnuctipun will return
Old 3rd April 2009, 04:08 PM   #4
With both plate to screen (Triode Strap) and cathode Schading
in effect simultaneously, your output stage voltage gain may be
very very low. You are going to need a really big drive signal.
Drive of that magnitude might venture into grid conduction.
I would suggest you simulate in LTSpice before committing.
Will providing that current cause the very distortion you wish
all this local feedback to prevent?
Might want to keep your options open for a Pentode or UL
screen strapping. If you are going with strong local feedback
into the cathode...
Remember the work of OHSchade(RCA 1939). This sort of
feedback makes almost the same curves as Triode anyway.
Old 3rd April 2009, 05:06 PM   #5
into the cathode...
hey-Hey!!!,
The grid-cathode drive requirements are the same in any of these topologies, including the unity-coupled McIntosh. The large voltage is seen grid-ground, but that becomes a driver capability issue, not a power final grid current problem.
cheers,
Douglas
Old 3rd April 2009, 10:00 PM   #6
Doh!, I forgot the cathode swings with the input, not against...
Old 4th April 2009, 11:55 AM   #7
heh-heh-heh...against would be positive FB. You'd most likely encounter this if the winding polarity was not established before hooking it up...
cheers,
Douglas
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 08:07 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
Transformer Windings impsick Chip Amps 6 2nd February 2007 11:00 AM
calculating windings for mH Madmike2 Parts 13 4th July 2005 02:49 AM
opt windings, need some help jazz Tubes / Valves 13 7th November 2003 02:50 PM
Page generated in 0.11015 seconds (81.89% PHP - 18.11% MySQL) with 10 queries
