| diyAudio Sponsor | ||
Alright so I've been bitten by the transformer winding bug and decided to finish my plans to actually wind a pair. My goal is two SE transformers for the 6C33C tube, mostly due to the low impedance.
I have a supply of EI-150 M6 lams and have been playing with Yves' OPT calculator. In the section to pick the lamination size there are three listings for the EI-150. EI-150NA, NB, and NC. I can't find any specs for these suffixes. Does that mean how thick the stack of lams will be? EI-150NA looks to be the biggest because AFe (cm2) and the wire length both increase. Lastly, I found a company who makes bobbins and is willing to sell me a few. http://www.foremostplastic.com/Page8.html Look at part number 5-3379 for example. Does that mean a stack 1.5" thick? Any input is appreciated. |
#2 |
EI-150 X 1.5 2FL, PN:5-3379
A quick guess, I think it should be the thickness. 2FL, maybe is the bobin center divider |
#3 |
additional info,
As I know Yves' OPT calculator, have a database file. You can open it up and see the EI spec. or add new EI spec. You can also calculate the cross section area by ; Afe = T x S. Since it is the same EI-150, the T is same, so the only difference is the S, (stack) |
#4 | |
This site gives a little more detail http://www.mfkbobbins.com/unterm_rec.html
3.81(Y)=30.1 Y=7.90cm or 3.11" A stack 3.11" high. NC is a stack 4.34" and NA is a stack 2.29" Odd sizes when most bobbins seem to be made to .25" increments. Looking at the core.tbx file didn't help much EI150NC=42.1,9.7,30,20.4,68.7,37.1 EI54=2.94,0.243,10.8,7.1,24.3,10.5 EI60=3.7,0.34,12,8,26,11.7 EI66A=4.46,0.45,13.2,9,28.7,12.8 |
#5 |
Just a followup about the core data. If you edit the core data in the program the window has the names for the values listed.
| ESL transformer questions | mjon | Planars & Exotics | 7 | 21st June 2008 05:12 PM |
| Transformer questions | synthius | Chip Amps | 18 | 10th December 2007 10:28 AM |
| transformer questions | woodturner-fran | Tubes / Valves | 9 | 12th March 2007 09:09 PM |
| Transformer questions | Trout | Tubes / Valves | 3 | 1st February 2005 01:19 PM |
| Transformer questions... | Nappylady | Chip Amps | 5 | 30th October 2003 12:28 PM |
| Page generated in 1.74285 seconds (4.39% PHP - 95.61% MySQL) with 11 queries |
