diyAudio Sponsor
Old 1st April 2009, 02:10 AM   #1
eeyore is offline eeyore  Australia
Default Audio Note Kit 1 PSU question
Can anyone confirm the current rating required for the choke of the AN Kit 1? I am thinking of getting the kit and adding/changing the PSU choke, since it does it for both channels, I am not sure what the current rating is, I was planning on getting a 150mA choke for this purpose. Would it be suitable? Thanks.
DF
http://diy-audio-blog.blogspot.com
Old 2nd April 2009, 08:55 PM   #2
работник
Rod Coleman's Avatar
For 2 x 300B SE (60..75mA each) and 4 preamp stages for stereo (8..10mA each) I would work on a 200mA minimum rating...
alternatively, separate chokes for the preamp stages makes quite a bit of difference to the sound, I believe.
If you get the 150mA rated part, can increase the 300B cathode resistance to reduce current. I like 300B-SE at the 360V 60mA recommended by Western Electric - as best sounding and kind to the valves.
Old 2nd April 2009, 09:46 PM   #3
"If you get the 150mA rated part, can increase the 300B cathode resistance to reduce current. I like 300B-SE at the 360V 60mA recommended by Western Electric - as best sounding and kind to the valves."
....and You must increase mu preamp, change its anode and cathode
resistors.....I don't prefer You....The sound is different, If You use 300B
with Ia=50. 60, or 70 ma.
Old 3rd April 2009, 12:29 AM   #4
KT is offline KT  United States
Hello,
I purchase and built the Audio Note Kit One back when it was sold by Angela Instruments, around 1997.
The choke that came with the kit at that time was specified at 10H/200mA.
I don't know if the specs have changed since then, but this seems to be around the range suggested by others.
Best,
KT
Quick Question - Audio Note M1 or AR SP-6? john65b Tubes / Valves 8 1st March 2009 03:03 PM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 05:17 AM
Audio Note M1 potentiometer question FrancoB Tubes / Valves 1 26th February 2005 02:15 PM
Audio Note Kageki vs. EAR 859 vs. Audio Innovations: The First Vortex Tubes / Valves 1 2nd February 2004 12:31 AM
Audio note dac Kovax Digital Source 9 17th February 2003 03:33 PM
Page generated in 0.07634 seconds (76.57% PHP - 23.43% MySQL) with 10 queries
