diyAudio Sponsor
Old 30th March 2009, 04:34 AM   #1
kegger is offline kegger  United States
Default West Output Transformers?
Anyone have any info or clues on this pair of outputs I have?
(No other markings but what the pic shows)
They came on a hombrew PP 6550 amp picked up off craigslist.
They have UL taps along with what I assume 4, 8, 16 ohm output taps.
Old 2nd April 2009, 05:46 AM   #2
Enzo is offline Enzo  United States
Check out the West web site. Maybe your part is there. If not, then contact Dave at West Labs and ask about them. he built the amps that used them, if anyone has information on them it would be he.
http://www.westlabs.com/
Old 3rd April 2009, 04:03 AM   #3
Thanks Enzo, I had looked that direction and read the info there a
while back but no real clues, I've seen others mention trying to get
info from them without much results but I still may try.
I was leaning towards a Dynaco connection from there and after a
bit of closer inspection they are basically identical in size and looks
to the MARK III outputs down to the same wire colors, which if that
is the case may make that West connection even more probable as
they mention taking Dynaco an stuffing it in a box like Sunn had done....
HUMM.......
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Use 2X SE output transformers fo 1x PP speaker Tubes / Valves 4 25th February 2009 06:03 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
WEST output transformers? kegger Tubes / Valves 0 28th October 2008 06:12 AM
MOT's as output transformers? ak_47_boy Tubes / Valves 9 15th September 2007 08:00 AM
Page generated in 0.06895 seconds (69.00% PHP - 31.00% MySQL) with 11 queries
