problem with 12AE6A buffer
Old 29th March 2009, 02:50 AM   #1
ionomolo is offline ionomolo  United States
ionomolo's Avatar
Send a message via MSN to ionomolo
Default problem with 12AE6A buffer
I've done a tube buffer for solid state amps using a 12A6A (millet-like) mu follower biased at 700 uA/18V using grid feedback and i got some weird stuff.
At first everything is fine and the sound is exellent, but after a while i start to hear the radio and some cracking trough it, and the sound degrades a bit. I belive this is instability due to a too long feedback loop (7 cm including parts length). Am i right? Has somebody gone through something similar?
EDIT: Feedback is done by anode -> 1uf -> 100K -> Grid -> 100K -> Input
Bias is done in the cathode using a 5K potentiometer paralleled with a 470 uF cap
Old 29th March 2009, 11:10 PM   #2
pointy is offline pointy  United Kingdom
pointy's Avatar
if you are getting radio and static the odd photon, phone call from mars etc............ .
may be it would be best to put the whole lot in an earthed metal box.
ie. like a valve power-amp base.
or like a bread-board with a cake-tin over the top.......... me amigos!
Old 29th March 2009, 11:40 PM   #3
ionomolo's Avatar
Thanks, this will help make the amp even quieter.
The big problem however is already solved, it was the heather voltage that was floating with respect to the cathode.
problem with 12AE6A bufferHide this!Advertise here!
B1 Buffer and some help please!!!! Malka07 Pass Labs 4 28th May 2012 07:18 PM
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
My pre-amp / buffer SimontY Solid State 12 15th November 2008 05:48 PM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
A Buffer ? Why ? Elkaid Chip Amps 29 15th September 2003 12:40 PM
