Funky Looking 15DQ8s - Page 2 - diyAudio
Old 29th March 2009, 05:09 AM   #11
smoking-amp's Avatar
Sounds like it could be a tube for George (Tubelab) to test. He could see how many watts it will draw before the bulb blows. Unless they glow a nice color at low power, then maybe VR duty or as a nightlight.
Old 29th March 2009, 11:02 AM   #12
ilimzn is offline ilimzn  Croatia
These are probably made by Tungsram in Hungary. For some reason this sort of thing is quite common with some of their tubes (another example would be their EF80 pentodes), they are new and they seem just fine like that. I am not sure it's directly related to getter firing, but may have to do with the initial tube out-gassing or initial heater firing. Wether it's some product of the heater burn-in that radiates out from the insides onto the glass through the anode holes and looks like that, or subsequently somehow attracts the getter material, I have no idea.
Old 29th March 2009, 11:55 AM   #13
I'm currently listening to an amp using a quad of E84Ls branded as "National" by Richardson but "made in Hungary" so most likely Tungsrams. They have very similar getter patches and they work just fine.
Old 29th March 2009, 05:23 PM   #14
Alastair E's Avatar
Nah, Nowt wrong with those.....
Seen this many times with European tubes.....
I have a number of EF184 and EF183's that are exactly the same, and made by some Co For Mazda...The tubes I have are NOS and in their original boxes too..............
Das Beste Oder Nichts
Old 29th March 2009, 08:21 PM   #15
wrenchone's Avatar
Thanks for the replies. I'd never seen getter distribution like that before. The 15LQ8 is nice in that it has a high voltage rating for both halves, though the triode and pentode don't have specs as impressive as, say, a 6LQ8. I'm getting infatuated with some of the triode/pentode duals floating around out there, especially the ones where the pentode is designed for video amp duty.
Class D amp, one channel ... funky. guitarcarl Class D 1 20th November 2008 08:57 PM
funky power supply audio_moksha Tubes / Valves 10 19th March 2008 03:51 AM
Funky reading 12B4A? kegger Tubes / Valves 14 13th November 2006 07:23 PM
Funky 70's SAE preamp and amp (ebay) Jason Swap Meet 0 8th April 2005 11:51 AM
Copyright 1999-2017 diyAudio
