How to Install UX4 Socket without Punch
Old 23rd April 2003, 04:15 AM   #11
Saurav is offline Saurav
That looks really good, but it's more hardware than I have. Is there any way to do this with hand tools? I guess not...
Old 23rd April 2003, 04:25 AM   #12
Ciscokid is offline Ciscokid
Default Sure there is...
I have not done it.. but others simply etch the circle with a compass type device and drill very small holes (nearly touching) along the inside of the circle. Then, remove the inner piece and use a file to smooth the drilled holes down to the etched circle. Hope this makes since...
Ck
Old 23rd April 2003, 04:27 AM   #13
Default Sure there is... cont..
Oops ...
I forgot to mention in above post... "using simple hand drill"
ck
Old 23rd April 2003, 07:17 AM   #14
OK, that sounds like a more doable idea. Why didn't I think of that? It's pretty obvious More time consuming for sure, but that's not a concern for me.
Thanks,
Saurav
Old 23rd April 2003, 11:31 AM   #15
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Default Bradrad
Have you guys tried these? We got these from Farnell.com
From 8 mm to 3.8 cm (3 mm steps) hole, up to 3 mm thick aluminum or steel
Old 23rd April 2003, 02:27 PM   #16
JBasham is offline JBasham  United States
You can get the big Unibits from EBay sellers, new, for $20 or less. If you're only working with 9 pin tubes, the smaller Unitbit does up to 7/8 inch, which is fine for 9 pin sockets. It can be had for $10.
You can't use them on the couch, but they make better holes than a punch, and give you a range from 1/8 to 1 1/8 inches in 1/8 inch increments, for $20. Just put a little cutting oil (or even bacon grease) on the work, and run the drill at low speed.
I wouldn't try to use the big Unibit without a drill press. But, a $50 variable-speed belt drive import job from EBay will do the work just fine -- I've made at least six chassis with mine, in aluminum, copper, and steel -- and is useful for a bunch of other jobs too.
The only true thing in audio is what you hear with your own ears.
Old 23rd April 2003, 04:39 PM   #17
Well, I'm living in an apartment now with no garage, so I think a drill press is out. I'm still trying to figure out how I'm going to carry out my plans to build an amp.
Old 23rd April 2003, 05:33 PM   #18
karma is offline karma  Canada
karma's Avatar
Unhappy heh
trust me its not easy in a apartment
i miss my garage to
Old 23rd April 2003, 08:54 PM   #19
mig-ru is offline mig-ru  Russian Federation
Hole drill bits (aka hole saws) will work with hand drills just fine, just not as steady/accurate as with a drill press, but that goes for all drill bits used with a hand drill.
How to Install UX4 Socket without PunchHide this!Advertise here!
Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY ppia600 Swap Meet 0 23rd February 2008 02:17 AM
My experience: the cheap punch set VS Greenlee punch vax9000 Tubes / Valves 5 21st July 2006 08:52 PM
new install maxiboy Car Audio 6 26th June 2005 11:06 PM
Amp install Help PlEaSe. ebwilliams Car Audio 5 8th September 2004 04:28 AM
How do i install a cap? mcyates Multi-Way 7 21st February 2003 09:20 PM
Copyright ©1999-2017 diyAudio
