| diyAudio Sponsor | ||
Hi folks,
Can twisted AC wires (HV or heater) induce hum in (quality) transformers if they run close to the transformer? If so, how close is too close? I am not talking about the proximity or orientation of the power transformer to the output transformer but rather the AC secondary leads. As a supplementary question, if induced hum is possible, would a 2mm aluminum plate between wires and transformer act as a shield? Obviously, the simple solution is to keep the two separate but for various irritating reasons this is not easily possible with my current chassis. Any input welcome. Thanks in advance. Rob |
#2 |
This induction is definitely not an issue at output levels. And the 2mm alu will have practically no effect.
#3 |
I'd only worry about it if the transformer is an open bracket interstage transformer that is being used in low level circuitry.
The twisted pair should be pretty resistant against causing this sort of thing. |
#4 |
No.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
First off...Aluminum is a non-magnetic metal and will not "short out" a stray unwanted magnetic field.
If I recall, Morgan Jones made a notation to twist-per-inch of such lines. The twisting has a nulling effect for magnetic fields. It would be a nice study of twisting 'rates' vs. field 'output'???? Seeing how some run these lines, I have the impression a "flanking manouver" with twisted pairs is a viable wiring technique. Rather...not trying to do a shortest possible but a sweeping route thru the chassis...trying to maintain the longest distance between other wires. This of course will look kinda kooky with the twisted pairs floating thru the chassis toward their target. I have the impression fields generated by twisted pairs is measured in millimeters. EG..3-7mm _______________________________________________Ric k........ |
#6 |
Thanks for the replies,
Normally I run all of the AC power lines away from any of the signal path, including the output transformers. Unfortunately the penetratrators for my power transformer leads ended up very close to my output transformer as I was forced to move my output transformers due to a problem with the original design of the chassis. Anyhow, this is good news. Cheers and thanks again. Rob |
#7 |
it could be that the transfromers are acting on the ac wires. if so screen them.................................i think ?
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| Ferrite bed od the wires who goes to output transistors ? | gaetan8888 | Solid State | 5 | 21st June 2007 06:50 PM |
| Conductors (I.C.'s, RCAs, internal wires, speaker wires) | bigphil | Parts | 1 | 25th November 2005 06:47 PM |
| wires of output transformer are too thin! | zxx123 | Tubes / Valves | 5 | 4th February 2005 10:18 AM |
| Page generated in 0.08914 seconds (74.40% PHP - 25.60% MySQL) with 10 queries |
