diyAudio Sponsor
Old 23rd March 2009, 05:32 PM   #1
Default RCA preamp modification
I want to modify the attached schematic that is posted in the RCA tube manual. I would like to use the preamp without any bass or treble controls. What do I need to remove in order to use this as a straight preamp?
scheamtic
Old 23rd March 2009, 06:51 PM   #2
Hi!
You can connect cap 0.1 uf from cathode 1-st triod to 1-st grid /pin 8/.
From pin 8 to ground - resistor 1 mom. All elements around "bass"
and "treble" You must disconnect /0.1mom, 1 mom, 10000, 0.0022,
0,022, 0.1 mom, 220, 1 mom, 0,022/.
Old 23rd March 2009, 06:58 PM   #3
Excellent!
I will try that out..
Thanks.
Modification..... Actuary Tubes / Valves 3 26th February 2008 02:34 AM
Amp Modification shajan Solid State 3 5th January 2004 07:21 PM
Zen modification tschrama Pass Labs 8 29th December 2002 06:59 PM
Modification of an headphone amp to real preamp FrankDIY Headphone Systems 6 4th December 2002 12:55 PM
Page generated in 0.06680 seconds (70.15% PHP - 29.85% MySQL) with 10 queries
