| diyAudio Sponsor | ||
Hi everybody,
I have a few Westinghouse 6AU6A tubes sitting around and was looking at building a low powered tube amp. I plan on connecting it in triode mode. I know there is probably better devices to do this with, but because I have these, I wanted to try to build something useable out of them. Right now I am looking at the output stage only. I intend to use this as a guitar amp and want it micropowered so it doesn't get very loud when I crank it up. I also want to use only 1 tube for the output. The datasheet on this tube says to use 250V for the plate voltage and 330 ohms for the cathode resistor. The plate resistance is ~7.5k ohms it says, so I would use a transformer with a 7.5k ohm primary when it has an 8 ohm load on the secondary. I have found some information in some books on building Class A transformer coupled stages. Using this to crunch some information I have found that the power output would be ~0.25 watts if I move Ec1 between -1 to-7. What I am asking is, is there a better bias point for this tube? The datasheet says the maximum plate voltage in triode mode is 275 volts. The numbers I have crunched show that it will peak at 300 volts if I pull the grid to cathode voltage down to -7. Thanks. P.S. - Datasheet http://www.mif.pg.gda.pl/homepages/f...93/6/6AU6A.pdf |
#2 | |
#3 |
This thread from two weeks ago might be of interest
http://www.diyaudio.com/forums/showt...46#post1761946 |
#4 |
Thanks for the responses.
I read that thread the other day. I was kind of wondering if a 10k load would work better. I guess I will have to try and see. |
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 04:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| tube driving the same tube - whats the collective word? | zobsky | Tubes / Valves | 3 | 13th June 2005 06:47 AM |
| Page generated in 0.07530 seconds (76.50% PHP - 23.50% MySQL) with 10 queries |
