Yet another DHT filament supply
Old 22nd March 2009, 07:27 PM   #1
astouffer is offline astouffer  United States
astouffer's Avatar
Default Yet another DHT filament supply
This idea came to me after doing some work with vacuum fluorescent display tubes. If the filament is lit with DC then long segments will be bright at one end and dim at the other so using AC solves this problem.
I used a 7404 hex inverter set as an oscillator of around 200Khz and took the output and used it along with its inversion and fed that into an L298 bridge motor driver. The result is an AC square wave. This got me thinking about trying it with DHTs.
The general agreement is DHTs sound best with AC filaments and low voltage switching supplies are dirt cheap. So use an opamp like an OPA340 (single supply and rail to rail) as sine oscillator driving a mosfet bridge. Get some logic level low Rds mosfets and you could probably mount all 4 on the same heatsink. Use a frequency of maybe 400-500Khz and I don't see how that would be any worse than dealing with 60Hz hum.
Old 22nd March 2009, 07:30 PM   #2
korneluk is offline korneluk  United States
korneluk's Avatar
OK - I'm game. Post some more details and I'll build one.
Old 22nd March 2009, 09:42 PM   #3
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Default Re: Yet another DHT filament supply
My sense is that DHTs sound best not because of AC, but in spite of it. With just about any DC supply, if you look at the AC signal current path, it travels through at least one cap (either after the regulator, or on the end of the RC or LC filter) which degrades the signal. With AC, it is just through a transformer, which likely does less damage. The one DC exception is a CCS supply, and a CCS worth using has no caps after the CCS, and blocks AC meaning that the AC signal current avoids the capacitors.
Old 22nd March 2009, 10:06 PM   #4
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
When doing the initial design on the Tubelab SE I found the following. I started with an AC powered 45. It was fed in the usual way with a hum balance pot across the filament transformer, wiper grounded. I could indeed null the hum like you are supposed to. The prototype was built and I was playing with things like driver transformers, cathode followers and eventually the mosfet driver circuit that I now call PowerDrive. All along I sensed that something just didn't sound quite right. It was most obvious when I plugged an acoustic guitar straight into the amp and plucked a single string. There was a fuzziness that didn't belong. It dissapeared as the note decayed.
It was at about this time that I discovered the FFT analyzer. This new design tool uncovered the "fuzz" imediately. It was IMD products created from the fundamental guitar note mixing with the 60Hz present on the 45 filament. The output had 60Hz sidebands that were strongly dependent on the level of the fundamental note aven though there was very little 60Hz present in the output. These IMD products appear well before clipping, and slowly drop off as the amp hits hard clipping.
I substituted a DC power supply for the filament transformer and the fuzz (both audible and measured) was gone. This is why the Tubelab SE uses a DC filament supply. One side of this supply is directly grounded so there are no added caps in the signal path. I realize that this flies in the face of the "DHT's sound best on AC crowd", but it seems to work for me.
I briefly experimented with high frequency AC heating a few years ago. I got fruatrated with blown mosfets and gave up. I think (but have not yet proven) that you want your AC frequency to be a good deal above the frequency response of your OPT to keep IMD to a minimum. This should be easy with todays parts. If the frequency is high enough, a square wave may be OK. Again this is an unproven guess.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 22nd March 2009, 11:03 PM   #5
revintage is offline revintage
Have given the subject some thought and wonder if DC is the best as the potential is different from one end of the cathode to the other. I havenīt the knowledge in deeper tube theory to know if this a bad thing.
Anyway the idea of high-frequency heaters, why not fed from a CT grounded transformer, appeals to me.
At the moment I am planning a compactly built trioded 813 SE(got a pair NOS of Philips QB2/250A at a hamfest nearby ) where my idea was to ground one end and feed the heaters with a SMPS followed by a CCS. Same capfree solution as dsavitsk mentioned.
If there was a hf-solution ready I would go for that. P. Millet have a thing about hf-heaters on his site but is was made a while ago.
Old 22nd March 2009, 11:53 PM   #6
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Hint: use resonant converters
Old 23rd March 2009, 12:40 AM   #7
On the 45 tube the potential difference between one end and the other is 2.5 volts the bias voltage can be in the 50 volt range. I don't think 5% is a big deal. The 300B is worse at around 8%. Ditto the 845. The problem lies with high Mu tubes like the 811A The filament voltage can be higher than the bias voltage for some operating conditions. Here only part of the filament will be used when fed by DC. Coincidentally these tubes are the worst offenders in the hum department. If you want to test out a HF heating system the 811A would be the worst case test subject.
Old 23rd March 2009, 02:14 AM   #8
astouffer's Avatar
Ok this is only a proof of concept and I really don't have an immediate need but this is still interesting.
Old 23rd March 2009, 03:34 AM   #9
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I really think you would be opening up a BIG can-o-worms by running that high a F. Coming from one who understands analogue(sp?) TV on a basic level....low end RF brings out unanticipated consequences.
One that might crop up would be an electrical stiction of the filiments as such the voltages the filiments "see" would rise.
George is right....even at 60 Hz problems crop up...NOW you run a square wave and you can be certain something unexpected will rise up to foul things up........experiment and see.
__________________________________________________ Rick....
Old 23rd March 2009, 04:13 AM   #10
That looks too much like my original fet smoker. It took a few blown fets to figure out that H bridges only work with square waves. Apply a sine wave and you get "shoot through". This is what happens when the top and bottom fets turn on at the same time. The power supply "shoots through" the fets leaving bullet holes!
The design that worked best resembled a push pull amp with mosfets where the tubes belong. The OPT was a 1 inch toroid. Efficiency sucked but I was using 20 year old hamfest mosfets.
Yet another DHT filament supplyHide this!Advertise here!
K-502 Filament supply (or K-12M) jmillerdoc Tubes / Valves 6 18th November 2009 01:59 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 02:06 PM
LV Filament supply quandry selfwilly Tubes / Valves 6 8th July 2006 08:10 PM
DC filament supply LC or CL TBM Tubes / Valves 1 7th August 2005 08:26 PM
When using a DC filament supply on a DHT... Saurav Tubes / Valves 31 18th September 2003 06:03 AM
Copyright ©1999-2017 diyAudio
