| diyAudio Sponsor | ||
Hi everyone. This is my first post on here.
Anyone got this amp and had this particular problem.... I am getting coneflap through the left channel only when i use the TT. However the coneflap is not the problem. The problem is that the right channel is not letting through anything below about 25Hz whereas the left channel is going right down to about 1Hz. I have verified this with a function generator. Anyone know what the problem could be? The amp has been repaired before (not by me) due to a volume mismatch. I could probably repair it myself but i need a circuit diagram. Anyone got one? |
#2 |
hi all
im looking for a service manual/ schematic for this model. fault i have noisey on power down bothe channels any help apprietiated
regards bob |
#3 | |
Lifes too short to listen to bad music |
#4 |
yes and it has got progressively worse, now it is so bad the customer fears his speakers will be damaged.
regards bob |
| Mcintosh MA 2275 | burbeck | Tubes / Valves | 2 | 24th April 2009 11:00 AM |
| McIntosh 2120 SCHEMATIC | The G.O.A.T.145 | Solid State | 6 | 10th March 2009 01:48 PM |
| McIntosh 225 Schematic | santosa | Tubes / Valves | 3 | 8th June 2005 09:08 AM |
| McIntosh Schematic - Mac 250 transistor power amp? | PB2 | Solid State | 26 | 29th March 2005 10:14 AM |
| schematic for for McINTOSH C30 preamp | sean | Tubes / Valves | 0 | 1st May 2003 05:42 PM |
| Page generated in 0.07476 seconds (72.47% PHP - 27.53% MySQL) with 10 queries |
