| diyAudio Sponsor | ||
Hello,
Are there calculation rules for bleeder value (ohm) and especially rating (watts)? I intend to use allen bradley 2w resistors as this part now has a strong influence on sound since i have upgraded all other parts. The bleeders are now Mills 12w, but i have found very good results when ALL resistors across the amp are the same type. Also, is there a better place to put it ? I have a psu with C1 - L - C2 - R - C3 (B+ output stage) - R - C4 (B+ input stage). Bleeders are across C2 and C4. thanks in advance eric |
#2 |
If the bleeder has any effect on the sound, you have some serious circuit work to do.
In any event, use T = RC to calculate the interacion of the capacitance, the bleeder value, and the desired discharge time. This will give you the time when about 60% of the voltage has been drained. For safety's sake, you'll want to wait about ten time constants before poking your fingers around. Power dissipated is the usual V2/R. Set the resistor power rating at least three times higher.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
In fact as i went upgrade my amp i just find that now ANY slight change has a HUGE effect on sound (most important i found being grid leak resistor : it changes the whole character of the amp).
It is certainly true because the amp is single ended, every part being actually "in the signal path". PSU = 100% Obbligato oil capacitors Resistors = all allen bradley except bleeders (mills) signal cap : jensen NOS PiO all wires are silver (except earth sides) no grid stoppers (you just hear them too much) Zero bypass capacitors (so higher primary Z on OPT and lower power) Fot the moment it is a 5V4 - 6SN7 - EL84 triode design. I'm sure there is no problem in my amp. I tried there a few different wirewounds (mills, welwyn, white coffins) and cheap carbon resistors (paralleled to increase power wattage). What i hear when changing bleeders is the same kind of sound difference if i had made a change somewhere else in the amp (i.e. cathode) with the same resistor type, with perhaps a slighter effect. But the change only occurs now the amp was strongly upgraded towards transparency. I will post another thread concerning my opinion about resistor brands later...problem is that you are never sure it is their sound or a sound they let you hear from somewere else...Kiwame was a very strong disappointment. If i understand well : ex : 100k bleeder under 350v charged cap is = 350*350/100k = 1.225 > 3w resistor but T=7s, so a longer discharge time. 33k bleeder means 12w but T=2s. My amp is effectively discharging in 10-15 sec now (using 33k) I will then parallel several Allen bradley to increase power rating and lower value and time. thanks eric |
#4 | |
#5 |
Bottom line is:
Once you have worked out the power rating and voltage rating see what choices you have in resistor...It might be limited. Heat is going to cause noise in any component...so higher wattage of the same preferred type is going to be better..(probably bigger) Again this is a personal choice what sound do you like....it's no good saying no sound because all components have an effect...It's a case of balancing the types so you get as close to neutral as possible. (Remember neural is a definite target, not a preference). The electrical properties are more important..ie if the component burns out but sounded great.... If you can remove induction and magnetic materials, then again the circuit board creates a dielectric between tracks... I guess you can hear a change in sound if you re-solder a connection and listen for about 5 mins…as it burns in. There is no answer to the question because each person may prefer a different “sound”. Quote “cheap carbon resistors (paralleled to increase power wattage)” Here is a thought…does paralleling resistors increase wattage?<<<I know you are going to say WHAT????? If a put two light bulbs in parallel across a supply does each lamp dissipate less wattage if the PSU remains up to voltage? Will two half watt resistors across a supply dissipate less in each one if they are across the supply? Or do you need a one watt? Regards M. Gregg
What is the sound of one hand clapping? |
#6 |
I'm with SY on this: if you can hear the bleeder resistors then they must be very noisy and your circuit must have very poor PSRR. You should be able to reduce any perceived effect by putting the bleeder across the reservoir cap rather than the smoothing cap, as this moves it further away from the audio circuit. The downside is that you might need a slightly bigger resistor as the voltage wil be higher here.
#7 | |
We are quite prone to think something sounds different if we have changed something, even, perhaps even especially, if it doesn't. |
#8 |
Certainly, if they are both twice the number of ohms ...
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it. |
#9 |
As I tried a lot of things for my single ended amp, I can say that even bleeder resistors do influence the sound (but perhaps only in very straightforward low parts SE amps?)
I do use Mills there. eric |
#10 | |
| transformer ratings... pls help | JojoD818 | Solid State | 32 | 23rd July 2010 10:42 AM |
| Subwoofer RMS ratings? | Flyin11 | Car Audio | 8 | 24th February 2008 12:52 PM |
| DCR ratings of inductors | Wamba-lam | Multi-Way | 6 | 4th August 2007 05:25 PM |
| Amplifier Ratings.... | mrfeedback | Solid State | 9 | 8th January 2003 10:26 AM |
| Are These Wattage Ratings Right? | CryingDragon | Solid State | 9 | 24th September 2002 06:48 AM |
| Page generated in 5.67145 seconds (2.79% PHP - 97.21% MySQL) with 10 queries |
