diyAudio Sponsor
Old 21st March 2009, 02:46 AM   #1
diesel_tech's Avatar
Send a message via MSN to diesel_tech
Default looking for the top 6080 amp schematics
I've got 4 6080WC tubes stamped JAN. I've been looking for a circuit to use these. What do you use and how do you like it, i'm looking for simple P-P with 12AX7, 6SN7 or similar for the driver. Any suggestions?
Jeremy
Old 21st March 2009, 09:55 AM   #2
Shoog's Avatar
My design philosphy for the 6080 is run them hot and low ie 100V (plate to Cathode) and 100mA. Bias them up with CCS to overcome their intrinsic mismatch issues. I have successfully used cheap main toroidals as outputs in this configuration. This will give you about 7W per PP pair in class A. I have also generally cap coupled the cathodes together for differential operation rather than referencing to ground.
Others will tell you to run them at higher voltages and lower currents, which makes the design of power supply and selection of output transformer easier. However I feel hot and low sounds better.
Front end would always be a LTP and I would be inclined to include a input transformer to maintain maximum gain from the LTP. If you run the outputs at the setting I suggest then you only need 60V ptp of drive from the front end - which will be very doable with just the front end LTP and something like a 5687.
This configuration will perform adequately well with no gNFB, but you can introduce a little back to the LTP if you feel it is needed.
Overall this makes for a lovely 2 tube per channel 7W class A beauty.
Shoog
Old 21st March 2009, 02:18 PM   #3
monyse is offline monyse  Canada
Default 6080 schematics
In my opinion one of the best 6AS7/6080 schematics I encountered is Wim de Haan's from the N
Old 21st March 2009, 09:43 PM   #4
Sorry for previous incomplete message ; Wim de Haan is from Neederland ; you can goggle his name or tape his site www.wimdeham.nl
monyse
Old 22nd March 2009, 09:22 AM   #5
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default http://www.wimdehaan.nl/
works better
6080 is also used in a good regulator by Jan Didden as published in Elektor this month. See also this forum.
Old 22nd March 2009, 03:17 PM   #6
grhughes's Avatar
Default DIFFICULT tube to match in a push pull stage
because of it's low mu. Unit to unit they are all over the place along with the 12b4a. Makes a great pass tube in a power supply which is what it was designed for.
"The gift of imagination is the gift of the gods imparted to a few for which they receive innumerable kicks in the a$$ their entire life." Le Corbusier (Edward Jenneret)
Old 22nd March 2009, 08:26 PM   #7
Shoog's Avatar
My experience is that if you can keep the standing current stable (with CCSinks), the tubes behave well and stay well behaved until the CCSinks can no longer maintain balance - at this point they begin to oscillate.
Shoog
Old 23rd March 2009, 01:25 AM   #8
Since the 6080 is the "industrial" grade version of the 6AS7, and the 6AS7 is popular for building OTL amps, you could try that. The design by Bruce Rozenblitz published is GlassAudio back in the early nineties is one thought.
Peace,
Dave
Old 23rd March 2009, 02:13 AM   #9
gain-wire's Avatar
Well imagine that...
about ten years ago, I decided to use MY 6080WBs for an audio amplifier project. I did it single-ended, though, with a transformer that I chose for its looks , (I know, stupid, I was young) and ran the whole thing at 30 volts. It worked!
I don't think I had more than 3 watts, but I wasn't looking for power. The driver was a Dynaco PAT-5 preamp. how bout that, solid-state driving tubes! It worked good enough for me...
Probably if the Dynaco put tout more than 2V R.M.S., I could have gotten more output signal.
that dynaco sold on ebay...
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
6as7/6080 Se Otl desperateaudio Tubes / Valves 103 6th January 2009 01:19 PM
6080 @ 800µA Question ... oldeurope Tubes / Valves 12 18th June 2008 08:45 AM
Headphone amp using 6SN7 + 6080? motherone Headphone Systems 10 19th January 2006 12:21 PM
Set 6080/6as7 needtubes Tubes / Valves 34 28th August 2004 04:40 AM
37 / 6080 pre-amp RichardJones Tubes / Valves 10 17th April 2003 06:03 PM
Page generated in 0.09508 seconds (83.83% PHP - 16.17% MySQL) with 10 queries
