#11 | |
As for the addition of a diode between the anode follower and cathode of the second triode, here is my updated schematic. There are references to the addition of a 47k resistor in the connection, but, there are also references to leaving it out of the circuit. I will go with the original recommendation from the forum unless someone can help me understand why I might need it ![]() New Circuit:
If it works, but I dont know why it works... is that a bad thing?? |
#12 |
R.I.P.
If you have 0.1V on the first cathode, then that tube has 100uA running through it.
Therefore, if the anode load R is really 100k, then you should only lose 10V in it, giving a anode volatge of 250 - 10 = 240. But you only have 19V, so I suspect your 100k anode R isn't 100k at all, more like 2-3megohms. Check it out, resistors can be wrongly marked, or go open from handling. Regards, Allen (Vacuum State) |
#13 |
I had thought somewhere along thos lines... I will take a look (I am going to remove the erisitor from the back of the valve socket) and re-wire with a new resistor on the turret board. I have new bag new 100k resistors somewhere. I did check the resistor value before soldering it in, but, I am not always that tidy so I could have picked up the wrong one... I am fairly sure it is OK though from the marknigs (I dont currently own anything bigger than 1M that I am aware of) unless it has been damaged in some way.
I am building a great list of to-do's here. Thanks all, keep em coming please. When I get to work on this I will run voltage checks at all points with and without valves in place and tie them to each test. This really is a great place for people like me to learn. Thanks
#14 |
Brilliant, A big thanks to everyone on the forum that contributed to this thread.
With the exception of leaving out the cap on the cathode of the first half of the stage it is in as per the above schematic and working a treat. I am almost embarassed to say what the problem appears to have been, but It was kind a wiring problem. Since re-wiring the valve socket the voltages all seemed to sort themselves out but still no sound... A little tweaking and studying the schematics and I realised the problem as not with the stage itself but how I was taking the output from the stage back into the EQ circuit.Now I have to work out how to try and eliminate the slight background hum I am picking up in the extra gain stage. Time to dig out some shielded cable I think, and unfortunately because of a lack of space in the chassis I have had to position the extra circuit close to and parallell to the AC supply for the heaters giving me a bit of cyclic hum... Perhaps a simple diode recifier to convert to DC would be a great call here. Thanks again!!
| 12AX7 gain stage output impedance | Dave Z | Tubes / Valves | 3 | 3rd February 2008 05:29 PM |
| high gain 12ax7 preamp from scratch? | fingerwizards7 | Tubes / Valves | 2 | 30th December 2006 05:56 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| simple BJT gain stage | hihopes | Solid State | 2 | 22nd September 2005 08:19 AM |
| Lowering gain in 12AX7 SRPP preamp | net-david | Tubes / Valves | 26 | 23rd December 2003 05:55 PM |
