diyAudio Sponsor
Old 19th March 2009, 10:18 PM   #1
Cool 2A3 power adjustments by channel
I have a custom made 2A3 power amp--- nicely made but lately I seem to notice that all my music seems to sound louder on one channet than the other--there is no balance knob only volume...I have put in 10-12 cd's and they all sound high on the right channel----is this where I need to adjust the bias? JD
Old 19th March 2009, 10:32 PM   #2
rdf is offline rdf  Canada
rdf's Avatar
It would help to know something about the circuit and the history of the problem. Do you have any details?
Ears aren't microphones.
Old 20th March 2009, 07:43 AM   #3
What kind of bias is there - fixed, or cathode ?
You must measure:
If fixed.....Ugrid on the 1 grid of tubes, and measure anode current. Results must be the sames.
If cathode....Ucathode resistor. Anode current for each tube = Uc/Rc. Results must be the sames. /50-60 ma apr. per channel/.
/I remember Eric Clapton's song...."Tulsa time"..../
Old 20th March 2009, 08:54 AM   #4
Tweeker is offline Tweeker  United States
If the amp is zero/low feedback, one channel could also have more gain in the preamp. Especially if it uses high gm tubes.
Be sure your foil hat has a good low impedance ground.
X-5 bias adjustments ROLIKOV Pass Labs 3 11th December 2008 09:49 PM
D1 Volume adjustments hifimaker Pass Labs 11 19th October 2007 10:18 PM
Fender Adjustments JDeV Tubes / Valves 6 7th April 2006 08:17 PM
bias adjustments raveenvijendren Solid State 8 11th November 2005 12:17 PM
Plate amp EQ adjustments? mike.e Subwoofers 7 7th June 2005 06:50 PM
Page generated in 0.07167 seconds (75.71% PHP - 24.29% MySQL) with 10 queries
