Anti-Triode SEPP, how to do best? - Page 11 - diyAudio
Old 19th April 2009, 06:22 AM   #101
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally posted by hihopes
I have downloaded the datasheet for irf9610 from International Rectifier, but it doesn't show the pinout - just says it is a TO220AB package. As far as I can find out, this seems to have a pinout of G,D,S (looking from the front). Can anyone confirm this? I am drawing up a PCB and obviously need to get this right. I can post a jpg of the PCB if anyone is interested, or would like to give feedback on it.
This is from a Samsung Electronics datasheet.
Old 19th April 2009, 08:55 AM   #102
Default PCB
Hello Hihopes,
Are you planning the PCB for two IRF9610 or for the, at least simmed better, one IRF9610 and BJT(MJ350) for the lower device?
Old 19th April 2009, 08:28 PM   #103
hihopes is offline hihopes  South Africa
Thanks - G,D,S it is.
The first PCB will be for the 2 mosfets. My past experience tells me that mosfets tend to be quieter, or at least more benign-sounding than BJT's. (J-fets are my real preference - after valves of course)
This will not be an Eagle or other commercial effort. I am doing it in Coreldraw. I print it out on label paper, stick the paper on to the top side of the pcb sheet and use it for a drilling guide. Then I connect the drilled holes as required with a black felt-tip marker and etch the board. Primitive perhaps, but cheap and effective. (I have built up a library of parts at exact scale in Coreldraw over the last few months.)
Old 23rd April 2009, 08:40 PM   #104
I will try to attach the PCB drawings.
Old 23rd April 2009, 08:46 PM   #105
If you print them out at the measurements shown next to the boards, they will be exactly to scale. All resistors are 1/4 w except those shown as 2w. There is an optional larger resistor instead of the parallel 2w's. It is shown in blue, but please note that since I did not have one to measure, I took a bit of a guess at the size of it.
Old 24th April 2009, 06:17 AM   #106
Why MOSFETs? The obvious solution should be to go for a PJF or MOSFET at the top followed by a PNP.
Even if MOS are easier to handle they are not the obvious choice due to their extreme capacitances. This also shows as they give a more restricted bandwith than with BJT.
Old 24th April 2009, 11:31 AM   #107
Salas's Avatar
I would listen to both. Its easy.
Old 24th April 2009, 07:14 PM   #108
Salas's Avatar
Did you think of space for sinking the lower part? There are voltage and current situations that it will need sinking.
Old 24th April 2009, 07:20 PM   #109
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
You forgot to put a capacitor on the PCB.
The Devil is not so terrible as his math model is!
Old 25th April 2009, 08:11 AM   #110
In the first place, why make PCBs for a prototype? Even if it, as in this case, seems very promising. As Salas indicates listenning test should be done.
I am eager to try the "CVS" as driver load in a DC coupled SE with trioded E280F and 6B4G.
In this case the "CVS" could be used to fine tune bias for the output tube.
Will be back with a full schematic.
SEPTOR AT-amp (Anti-Triode) being built revintage Tubes / Valves 36 16th October 2008 06:01 AM
ESLDD with "anti-triode" revintage Tubes / Valves 27 4th October 2008 08:37 PM
Screen Driven Dissimilar Pentode SE Anti-Triode Spud kenpeter Tubes / Valves 2 26th July 2008 02:22 AM
Sepp? Tim Wyatt Tubes / Valves 4 27th April 2005 06:34 AM
Copyright 1999-2017 diyAudio
