Anti-Triode SEPP, how to do best?
Old 19th March 2009, 07:28 AM   #21
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally posted by Wavebourn
Hmmm.... I'm afraid you will need too many LEDs. Like a Green Light District (GLD, SY?)
Here it is Wavebourn. This is what I think I can do with recycling my post#2 CCS (the green LEDs one on the post#17 pic).
Does this count for a cascoded Mosfet gyrator (electronic choke)? Did I get it right at all?
I have included a 12AU7 common cathode simulation so to see how it reacts. The 420R resistor on top of the first Mosfet sets the current. It can be a 500R trimmer for using other tubes, namely my 6V6 trioded or a 12B4A in another preamp that I wanna test the gyrator too. The 33K 10W feeds 10mA so the LEDs can work low noise, and its Johnson noise is filtered by the 47uF not to reach the cascode's gate.
Old 19th March 2009, 08:31 AM   #22
Salas's Avatar
Originally posted by Michael Koster
It doesn't matter really how you
develop the fixed voltage. It can be used with fixed bias because it
can regulate the plate voltage.
Michael
Can I get the fixed voltage from a divider on B+ ? How higher than the anode voltage it must roughly be?
Old 19th March 2009, 04:32 PM   #23
kenpeter is offline kenpeter  United States
So what happens when you filter the best ideas of
Michael J Koster, Wavebourn, and Nelson Pass
through the strange mind of Ken? Heck if I know...
Pretend Zen is a Triode, same thing only sandy.
Only trying to show you the active source servo.
I'll bend it around a real triode here soon enough.
Good Ash? Bad Ash? I'm the one with the Aleph.
******* evil mirrored clones, what can you do?
Old 19th March 2009, 04:36 PM   #24
So in theory:
At DC: its a Voltage source
At some subsonic frequency:
Its a gyrator of aproximately
equal and constant current.
Above 20Hz: Its Anti-Triode
or Aleph or whatever...
And LTSpice seems to agree.
Just needs a sourceOdyne
to flip a ground level input
common to the bottom rail.
Old 19th March 2009, 04:52 PM   #25
You might notice the oddball 3K3 in the lower Bootstrap.
Why? Cause currents in R7 and R8 tend to be the same.
With a Symmetrical 4K7, bootstrapping wasn't happening
at all for the lower end. Indeed, the collector lost a volt
or two somewhere.
Tweaking it to 3K3 gave it the same -30V peak as the
upper collector's +30V Peak. Problem solved...
Old 19th March 2009, 05:05 PM   #26
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
1. 47 uF in series with LEDs is odd. Instead of decreasing voltage variations it increases them. Remove it.
2. 220 uF in servo feedback is too high for 1 mOhm resistor. Recauculate it for a reasonable time constant.
3. Voltage divider in servo feedback is formed by equal 1MOhm resistors. You have to increase the value of a bottom one many times, or decrease a value of the upper one to set proper anode voltage. If you need voltage drop on the upper resistor about 3V, on lower resistor about 150V, what should be their values?
Start from selecting the value of the bottom one, like 10 MOhm. Actually, 1 MOhm will be high enough comparing with Rp of your tube, so 150/3=50, i.e. the upper one should have 50 times smaller value, i.e. in case of lower one 1 mOhm it should be 20 KOhm. Use 50K trimmer to set it properly. Then select the capacitance, say for 1 Hz corner with 20 KOhm resistor.
And the last, a mistake in your drawing: you connected servo feedback to LEDs. Disconnect it. Gate of the upper FET should go to the servo feedback divider.
The Devil is not so terrible as his math model is!
Old 19th March 2009, 05:17 PM   #27
Salas's Avatar
Problem is, how do I keep the upper Mosfet on, If I don't put LEDs on its gate? I guess with the upper divider Vdrop?
Old 19th March 2009, 05:40 PM   #28
Wavebourn's Avatar
It is the main point of my idea that Kenpeter described, "That is absurdly cool!"
Upper MOSFET generates current needed to keep a constant voltage on the plate!
Old 19th March 2009, 06:14 PM   #29
Salas's Avatar
OK, what to you think about this one?
Old 19th March 2009, 06:33 PM   #30
Wavebourn's Avatar
I would add 3 more LEDs in series. You have plenty of voltage available, use it.
Also, I would remove that 600 Ohm resistor: it is not needed here (it was needed for your version of CCS with stable gate voltage), increasing that 330K about twice. Better, as I said, use 1M resistor and 50K trimmer for breadboarding. Also, 47 uF is too high value: I would decrease it to say 2 uF using a metal film cap.
And, finally, I would consider different transistors (smaller capacitances for better frequency response) since you need about 5 mA only.
Anti-Triode SEPP, how to do best?Hide this!Advertise here!
SEPTOR AT-amp (Anti-Triode) being built revintage Tubes / Valves 36 16th October 2008 06:01 AM
ESLDD with "anti-triode" revintage Tubes / Valves 27 4th October 2008 08:37 PM
Screen Driven Dissimilar Pentode SE Anti-Triode Spud kenpeter Tubes / Valves 2 26th July 2008 02:22 AM
Sepp? Tim Wyatt Tubes / Valves 4 27th April 2005 06:34 AM
Copyright ©1999-2017 diyAudio
