Some Help with Feedback Please!
Old 18th March 2009, 07:09 PM   #1
coldcathode is offline coldcathode  United States
coldcathode's Avatar
Default Some Help with Feedback Please!
Playing around with some more junkbox parts, I came up with the attached schematic.
I have read all I can about NFB but I am still confused. Look at the feedback loop I put in the schematic. My assumptions were this:
Max swing in the positive direction thru the OPT primary is ~94V.
so at the secondary it is ~4V? (94/25 (turns ratio)
The ratio of the 100K FBR to 1K1 RK is .011 so I see about .044V to the cathode? If the gain without Feedback is ~50. What is the amount of gain I am loosing? So for say of argument if I didn't lose ANY gain would I see a negative swing on the output of -2.2V?
I am sorry if this seems like a total NOOB question but I just can't get my hands around the NFB thing. The distortion is already pretty low but what I am trying to do is experiment with the feedback. Once I understand it I can then play with different bias points to increase power and use the feedback to "fix" the increase in distortion.
BTW, the .22uF cap I was thinking will reduce the feedback below about 1Khz.
Ignore all the poles in the PSU I like to play with resistors & capacitors LOL
Old 18th March 2009, 08:50 PM   #2
kmaier is offline kmaier  United States
kmaier's Avatar
It won't work... you have to remove the cathode bypass capacitor on the input stage or it simply grounds out the feedback signal, i.e., no feedback.
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 18th March 2009, 08:57 PM   #3
Hey Kev!
Thanks, I was thinking that but like I said this whole NFB thing is confusing to me. So with the unbypassed Rk the calc's change. Since the gain of the AX7 stage is now only about 27?
So now about 1.1V? on the output of the AX7?
How do I calculate the feedback's effect on Gain?
And am I even on the right track?
Old 18th March 2009, 09:01 PM   #4
Regards, KM
You meant like this correct?
Old 18th March 2009, 09:04 PM   #5
Sorry I just realized I did not label the tubes
1/2 12AX7 input and Parallel 6V6's in Triode Outputs.
Old 18th March 2009, 09:15 PM   #6
kmaier's Avatar
Hi CC,
Hint.... RC30 pages 38-40 cover inverse feedback, aka negative feedback.
Regards, KM
Old 19th March 2009, 12:09 AM   #7
Hi CC,
Regards, KM
DUH!
Thanks for the hint! I didn't make the "mental" connection of Negative Feedback and Inverse feedback. Actually isn't "Inverse Feedback" the more appropriate name?
Old 19th March 2009, 02:27 PM   #8
Ok,
I read through the RCA manual and I STILL do not understand FeedBack. They explain it with a voltage divider & cap based upon a tranformer coupled section and take the feedback from the primary of the OPT.
Can anyone explain the basic method for calculating feedback taken from the secondary of the OPT and fed back to the input section?
Old 19th March 2009, 03:51 PM   #9
Bandersnatch is offline Bandersnatch  United States
I have seen representations where it is described as signal generated to signal returned. So, 12AX7 gain times (6V6 triode gain/OPT step down ) times fraction of secondary signal returned to the input.
cheers,
Douglas
the Tnuctipun will return
Old 19th March 2009, 10:30 PM   #10
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
There's a good explanation of designing for global NFB at Aiken Amps
Some Help with Feedback Please!Hide this!Advertise here!
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 09:03 AM
