diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Ballast Tube Current Source (http://www.diyaudio.com/forums/tubes-valves/140686-ballast-tube-current-source.html)
bequerel 18th March 2009 02:20 PM
Anyone tried ballast tubes as current source for filaments?
They are available as NOS in a wide range of currents.
Will they generate some form of thermal noise making them impossible to use in eg. a linestage? I suppose that some of you veterans have some hands on experience with them. ;)
Alastair E 18th March 2009 02:21 PM
Do you mean, Barretter or a voltage-regulator tube...?
tubetvr 18th March 2009 02:32 PM
The question if they are useable for audio has been debated before on diyaudio.com
Ballast tubes usually consist of an iron wire in hydrogen gas. They are very slow devices and as such not useable as current sources for audio application, the reaction time can be measured in seconds or 10s of seconds so for audio they would look almost like a short circuit or very low impedance.
Regards Hans
bequerel 18th March 2009 02:34 PM
These tubes:
http://www.antiqueradios.com/features/ballast2.html
I was under the impression that they were fixed current regulators?
(A typical set up would be: Transformer -> 3-pin voltage regulator -> ballast current regulator -> ECC88 filament.)
tubetvr 18th March 2009 02:47 PM
Yes, but they are 2 terminal devices built with a hot wire. The principle is that a wire increase its resistance when it gets warm thereby the current decreases, the wire cools off and finally you reach a stable operating point with an almost constant current. An ordinary lightbulb works almost the same way but the iron wire in hydrogen gas give a more constant current.
As the working principle is based on the heating and cooling of a hot wire they are very slow devices.
BR Hans
bequerel 18th March 2009 02:50 PM
BR Hans
Thanks for clarifying the principle, Hans. I just thought I had a bright idea... for once. :bawling:
Resources saved on this page: MySQL 18.75%
