diyAudio Sponsor
Old 18th March 2009, 09:07 AM   #1
dsavitsk's Avatar
Default CMRR from parallel heaters?
Does anyone know if one can supply noisy DC to each end of a heater with a grounded center tap (12au7, etc.) and obtain some level of common mode noise rejection? That is, can one use a DC supply that is noisier than one might use in this sort of arrangement?
http://www.ecpaudio.com
Old 18th March 2009, 09:55 AM   #2
Geek's Avatar
That's what a traditional hum balance control does.
Hum is induced via h-k leakage. If both sides of the heater leak equally, they cancel each other out.
The CT sometimes works, but is rarely perfectly balanced to leakage currents.
Cheers!
Old 18th March 2009, 12:48 PM   #3
Gordy is offline Gordy  United Kingdom
I do not know the actual answer, however I suggest that it would only work (in such as your 12au7 example) if the heaters were physically 100% anti-phase balanced within the unit. The few tubes that I have seen inside have clearly not had that structure, suggesting that you will simply get two dirty paths to ground, and most likely more noise.
Page generated in 0.06449 seconds (71.43% PHP - 28.57% MySQL) with 10 queries
