any simple circuits I can add to a dac?
Old 17th March 2009, 01:04 AM   #1
Tristanc1 is offline Tristanc1  Canada
Default any simple circuits I can add to a dac?
Looking to learn a bit more about tubes, I have 2 dac kits sitting here waiting to be assembled on is from audiodiylab the dac301, which I can't seem to find a link for anymore, and the Opus dac from the twisted pear guys, found here. Is there anything that I could add to either one of these dacs using tubes? Not looking for a performance upgrade or anything just looking to learn a bit more about the subject, so hopefully there's something relatively simple that I can get my feet wet with? I already have a commercial tubed integrated otherwise i'd go that route, and build a pre-amp or something..
If anything comes to mind let me know
Tristan
When I was young I really wanted a bicycle, I used to pray every night for god to bring me one. But as I got older I realized god didn't work that way so I stole one and begged for forgiveness.
Old 17th March 2009, 02:01 AM   #2
d to the g is offline d to the g  United States
wildburro audio
d to the g's Avatar
Lampizator!
Old 17th March 2009, 06:36 AM   #3
revintage is offline revintage
Iīd say that Lamp.....s tubecircuits arenīt the most impressive.
With the Opus there is no need for tube circuits. Just go for a good Lundahl transformer to go from balanced to unbalanced.
If you want to go tubes anyway, there are at least two threads in "Tubes" about about a "differential CF" solution for balanced to unbalanced. Kenpeter initially came up with the idea. You will need one 6DJ8/channel. This is the one:
http://www.diyaudio.com/forums/showt...81#post1666681
Old 17th March 2009, 05:51 PM   #4
Fantastic, thanks guys. I'll check into both of them and then come back if I have questions...Or should I say when I have questions!
Thanks!
Tristan
Old 17th March 2009, 08:00 PM   #5
dheming is offline dheming  United States
dheming's Avatar
There's also a simple single tube gain stage kit available from Deware: http://www.decware.com/newsite/zkit4.htm along with a simple power supply to go with it: http://www.decware.com/newsite/zkit5.htm
Old 17th March 2009, 08:14 PM   #6
kenpeter is offline kenpeter  United States
Wether you choose Transformer, Differential CF,
or Wakko (Differential White Cathode Follower)
The important detail is that they are differential.
All the above reject common mode noises the
cables might pick up along the way. To include
any power supply noise belonging to the DAC.
For that reason, you might want this built close
or into your amp, rather than closer to the DAC.
any simple circuits I can add to a dac?Hide this!Advertise here!
Connecting Virtual Ground Circuits with True Ground circuits?? Minion Solid State 1 12th February 2007 01:28 AM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 12:50 PM
85 powersupply circuits 58 charge circuits gev Power Supplies 0 31st July 2005 11:27 AM
Check: Simple Circuits Devil_H@ck Parts 19 9th June 2004 02:54 PM
Copyright ©1999-2017 diyAudio
