diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Bias Voltage (http://www.diyaudio.com/forums/tubes-valves/140549-bias-voltage.html)
AmpBuilder225 16th March 2009 03:28 PM
Bias Voltage
Hi, I suspect this is a trivial point, but I have the bias current required for each power valve in my amp of 36.5mA and I am not sure how to work out the bias voltage from this to enable me to pick potentiometers. Could anybody advise me here?
Poindexter 16th March 2009 05:27 PM
Just in order to keep this simple, what output tube are you using, and what voltage (plate to cathode) is it operating at?
Aloha,
Poinz
AudioTropic
AmpBuilder225 16th March 2009 05:42 PM
They're EL34's with 480V on the plate
Poindexter 17th March 2009 04:06 AM
Mullard & Co. say about -42Vdc.
Aloha,
Poinz
AudioTropic
AmpBuilder225 17th March 2009 12:27 PM
Thank You, That would make sense :)
Resources saved on this page: MySQL 18.75%
