| diyAudio Sponsor | ||
I'm thinking of using an UL SE OT, reversing the primary leads so the 40% UL tap becomes a 60% tap. It seems to me that the resulting curve would have less distortion while retaining the higher power output. Reference the 43% vs. 70% curves at this link:
http://www.mclink.it/com/audiomatica/tubes/kt88.htm Im using a Hammond 1627SEA with parallel EI KT90's if it makes a difference. Of course I would have a lower damping factor than in triode but still reasonable as SE goes. This design would give me 20 to 30 watts without resorting to higher voltage tubes and the added complications. I've used a single 300B with my speakers which is adequate most of the time but sometimes I want to turn it up to 11. |
#2 |
I'm not following how you're intending to do this. Isn't the percentage referred to the ends of the primary versus the centertap?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
I don't see a problem with doing that. The only question remaining is does it sound any good? The one thing I don't like about Ultralinear is that you have very little ability to adjust it. Once the OPT is wound, the die is cast, and all you can do is hope that they got it right.
Try it both ways and see if it makes a difference, and which way you like it best. |
#4 |
SY-
I'm using a single ended OT and changing the plate lead to B+ and the B+ to the plate. I think this would change the UL% as stated but I could be wrong. Am I changing the 40% tap to 20%?That's why I like to ask first. Miles- Yes, it is fixed when the transormer is wound, otherise I might use a different %tap also. |
#5 |
Ahh, sorry, I skipped right over the "SE" part.
Well, the strays will be different and the electromagentic coupling to nearby components likewise, but as Miles said, try it, ya never know.
#6 |
strays will be different and the electromagentic coupling.
That's the part I didn't think of. Gotta just try it. |
#7 | |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Steel Leads and Tinned Copper Leads | impsick | Parts | 0 | 19th April 2009 10:01 AM |
| Leads for ISCO PS? | Sherman | Tubes / Valves | 4 | 9th August 2006 11:04 PM |
| bending leads | theChris | Solid State | 6 | 17th April 2003 06:59 AM |
| Toroid leads? 4 or 6 | Al.M | Solid State | 5 | 26th November 2001 11:41 PM |
| Zen Leads | vdi_nenna | Pass Labs | 3 | 14th October 2001 12:46 PM |
| Page generated in 0.08492 seconds (79.95% PHP - 20.05% MySQL) with 10 queries |
