Sansui AU-111 tube amp schematic
Old 20th April 2003, 02:01 PM   #1
Glass_painter is offline Glass_painter  Israel
Default Sansui AU-111 tube amp schematic
Hello everyone,
I would like to build a replica of this amp which is a very good amp.
Can anybody help with the schematic ?
Thank you very much.
Glass_painter.
Old 20th April 2003, 02:09 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Default Re: Sansui AU-111 tube amp schematic
2,5 seconds googling reveals: http://www.bonavolta.ch/hobby/en/audio/sansui.htm
/Hugo
Old 20th April 2003, 02:24 PM   #3
Le Basseur is offline Le Basseur  Croatia
Le Basseur's Avatar
I don't want to be rude,but:
1.Rule No.1:"Use a transistor,go to Jail!" (I...I just quoted an ancient wisdom.....just kidding,mate!)
2.Are you sure you want to build this schematic?Because almost every RIAA preamp wich has the corection part implemented as a negative feedback...well,IT SU..S!
Sorry,don't be offended,but that's it in my opinion.
"You're smart enough not to think I'm a fool"
Ol'Romanian proverb
Old 20th April 2003, 03:58 PM   #4
First, thanks for the schematic, I am looking for a full version though not only the preamp.
Second, I use tubes whare it suitable for better sound not only for the sake of the tubes themselfs (I like the glow though), and some times transistors will do a better job then tubes (like noise wise in MC preamps), so what gives the best sound performance wins.
Thanks.
Glass_painter
Old 20th April 2003, 05:28 PM   #5
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default SANSUI.
On this site I found an e-mail address, maybe they can send you a copy of the schematic:
SANSUI
Other than that it appears this model was rebuilt around the millennium.
Good luck,
Frank
Sansui AU-111 tube amp schematicHide this!Advertise here!
Sansui AU-317 schematic pinco Solid State 10 15th November 2012 10:00 PM
sansui au-d5 schematic demons_wing Solid State 1 29th September 2005 05:05 AM
Sansui AU D5 schematic? aesse54 Solid State 0 9th March 2005 11:00 AM
Where to get schematic for old sansui amp? gtrmaker Solid State 6 11th June 2004 11:00 PM
