Two EI Power Transformers Orientation?
Old 10th March 2009, 03:11 PM   #1
kacernator is offline kacernator  Czech Republic
Question Two EI Power Transformers Orientation?
I will be using two EI power transformers for one amplifier in one chassis. One for preamp other for poweramp. How should I orient them against each other for minimal induced hum?
Thank you.
Old 10th March 2009, 03:34 PM   #2
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
There will be no significant interaction regardless of orientation - millivolts in or out of phase won't matter. The magnetic field THEY generate will vary though - move them as necessary to minimize coupling into output or other transformers. It's even possible that that positioning the two transformers for maximum coupling will result in the least radiated field...
Two EI Power Transformers Orientation?Hide this!Advertise here!
Physical orientation of transformers bereanbill Tubes / Valves 2 20th May 2009 01:00 AM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 11:44 AM
Quad II power amps......power output transformers!!! bwes87 Tubes / Valves 3 10th September 2008 03:20 AM
Orientation and phasing of transformers? Skorpio Solid State 0 29th July 2008 01:35 PM
