diyAudio Sponsor
Old 10th March 2009, 01:41 PM   #1
cjctan is offline cjctan  Singapore
Default Question on Hybrid Bridge using 5AR4
Hi All,
I am trying to build a power supply for my SET amp with a B+ of 400V , ~170mA.
If I am going to use a 5AR4/GZ34 with 2 SS diodes, what should be the voltage of my PT Secondary winding? Is the winding voltage 700Vac (NO CT)?
Thanks in advance.....
Old 10th March 2009, 02:11 PM   #2
revintage's Avatar
In the ballpark of 350V AC(not more) would be OK.
Brgds
Lars
Old 10th March 2009, 07:16 PM   #3
работник
Rod Coleman's Avatar
Hybrid bridge works very well. BUT GZ34 is much more reliable and better sounding if (almost) Choke-Input filter is used.
Use 10H 200mA choke (must be specially designed for choke-input duty)
UF4007 diodes
47n 1500Vdc capacitors across trafo secondary to snub recovery pulses
220nF to 680nF 1500Vdc MKP capacitor after rectifier.
If you can find a transformer with 450 to 475V secondary, you can get 400Vdc by adjusting the cap after the rectifier (higher C=higher V).
If you get too many volts, change GZ34 for GZ37 (but need extra heater current).
Old 10th March 2009, 08:47 PM   #4
Thank you both for your inputs.
Rod,
May I know the cap that you are referring above is still for a choke input filter? Meaning it is the cap after the 10mH?
Can the Hammond 193J with DCR=82ohms be used for this choke input filtering?
Am I right to say that if choke input method is used, the secondary winding voltage will be around 450~475V and 350V for Capacitor input?
Thanks....
Old 10th March 2009, 09:07 PM   #5
zigzagflux's Avatar
Rod almost exactly specified my power supply at 380V dc. I use the Hammond 193J. Runs very quiet, so you shouldn't have any issues.
Old 10th March 2009, 09:16 PM   #6
работник
Rod, May I know the cap that you are referring above is still for a choke input filter? Meaning it is the cap after the 10mH? Can the Hammond 193J with DCR=82ohms be used for this choke input filtering? Am I right to say that if choke input method is used, the secondary winding voltage will be around 450~475V and 350V for Capacitor input?
Use only a small cap after the rectifier (220 to 680nF) to protect the choke from fast voltage changes. This is still choke-input, or more exactly "quasi-choke-input" to give it a fancy name. The value of this cap will adjust the dc volts up or down a little. Use a good quality MKP here, 1500~2000Vdc rating.
after the choke, use a bigger capacitor - 100uF or maybe more.
Yes, 450~475V for choke-input, 350V for capacitor input.
I'd say Choke-input is much better, especially for SE amps.
Old 11th March 2009, 01:40 AM   #7
zigzagflux,
Thanks for you input.
I will use the 193J for the Choke-input filter.
Old 11th March 2009, 02:06 AM   #8
Rod,
Appreciate your further explanations.
I have clearer picture now and I will adopt your "quasi" design
Another question regarding to the cap after the choke. Will a 500V rating cap enough at this junction? As the choke-input and cap-input chart in the GZ34 datasheet will not be accurate in this case. Any idea how to estimate the max voltage after the choke for no load condition for a 475V winding with 680nF snubber cap?
Thanks again
Old 11th March 2009, 09:28 AM   #9
работник
With 175mA dc and 400V (or even 430V) from (quasi) choke input, the ripple-current of the 2nd cap will be very low. That means a 450V electrolytic will work - providing the 175mA is sure to be present.
Choke-input supplies need to have a minimum load to work right - and the voltage goes high if the load disconnects.
A quality MKP will be better - Ansar Supersound or LCR AG series - both are 630V. These sound much better, and will not worry if short voltage-spikes happen.
To experiment with cap values and power supplies, you need to get PSUdii !!
http://www.duncanamps.com/psud2/index.html
This runs well using WINE on a Linux system (surely the OS of choice for DIY-mongers), or if you insist, on Windows-98 etc.
To simulate the hybrid-bridge, change the TYPE to "full-wave" vacuum tube" which gives the same outcome.
here's a screenshot with 475V/680n/10H/100uF. shows....400V !!
The big 600V peak at the start should not happen with a slow warm-up rectifier.
Old 11th March 2009, 02:24 PM   #10
Hi Rod,
Thanks again.
I will try out the PSUD2.
May I know where can I purchase the LCR AG series online?
Hybrid Graetz Bridge alexg Tubes / Valves 3 9th April 2008 03:45 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
a 5AR4 after a diode bridge? what is the purpose? jarthel Tubes / Valves 6 20th March 2007 09:54 PM
TubeCad's Hybrid amp question Tyimo Tubes / Valves 9 1st September 2006 08:17 AM
Page generated in 0.10359 seconds (85.74% PHP - 14.26% MySQL) with 11 queries
