| diyAudio Sponsor | ||
I'm having trouble locating a schematic for this Power Supply
D D D Mfg. Co. Model 3-150B uses 6BG6 GA power tubes and is in the 19" rack mount configuration. any help would be appreciated, I seem to be striking out on with the usual web searches. Also the local ham radio flea market was lot's of fun. I risk being down 25 dollars if I cant fix this. Thanks Bob
#2 | |
Location: kansas city mo, and on occasion, around the world ...
Not Really case work like this would be, 'a bit more ' than $25 new. make a nice amp chassis. 44 |
#3 |
Chances are good that if you replace all the electrolytic and/or wax caps this power supply should work fine. Hopefully it was not modified or "repaired" by a previous owner. Give it the same treatment as an old amp or radio being fired up for the first time in years.
#4 |
Thanks astouffer
The good news is that the unit came with a set of replacement filter caps, witch I think are oil filled paper. I will be digging into it, but it would be nice to have the schematic. Perhaps I will just draw the schematic as I work on it. There are also some electrolytics I spotted. You know the multi section can type. So with something that old, it might take a multi prong attack. I will know more soon. I think that this was not made in any volume, so that could explain the lack of information. This is intended to replace a Fluke 406 witch is on loan from a goooooood friend, and he deserves to get it back. Bob |
| high frequency high voltage power supply... | moray james | Planars & Exotics | 6 | 23rd July 2008 07:57 PM |
| Low Voltage High Power Supply | thndr | Power Supplies | 4 | 2nd February 2008 12:33 PM |
| high voltage power supply | leemajcool | Power Supplies | 3 | 5th August 2007 11:40 AM |
| Page generated in 0.07506 seconds (73.16% PHP - 26.84% MySQL) with 11 queries |
