diyAudio Sponsor
Old 9th March 2009, 03:15 PM   #1
rtill is offline rtill  United States
Default cap question....
what does this cap do?
Old 9th March 2009, 06:22 PM   #2
DougL is offline DougL  United States
The cap * Av adds to the miller capacitance of the tube.
I have seen it used by Norman Koren (sp) to limit the HF input to an amplifier.
Search for "The Emperors new Amplifier".
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 9th March 2009, 06:32 PM   #3
coldcathode's Avatar
Might be used to "filter" RF frequencies from getting amplified?
Or as Low Pass filter but not the best way to do it.
Old 9th March 2009, 06:38 PM   #4
For an accurate figure of what it "actually does" we would need to know the Grid resistor value, the gain of that stage and the tubes input and G-K capacitances. If you can calc the actual miller of the tube then add the 22pF you can calc the LP F3 point using the grid leak resistance.
Old 9th March 2009, 07:12 PM   #5
Miles Prower's Avatar
Default Re: cap question....
it adds an additional 22pF to the VT's reverse transfer capacitance. As to why you would want to do that, there are any number of reasons. If this is an audio amp's VAS, it will increase the Miller capacitance to roll off the high frequency response. You'd want to do that to either enhance the stability under gNFB if excessive open loop gain is causing instability, and/or to reduce an otherwise excessive bandwidth. To amplify audio, you do not need a high frequency cutoff of, let's say, 200KHz. (You're more likely to see this done with solid state amps since transistors are natural high gain devices, whereas VT's are not. Also, SS amps require a lot more gNFB in order to linearize these highly nonlinear active devices. That, in turn, can lead to excessive BWs.)
You would also add that capacitor if this is part of a "Miller" oscillator that's operating at low frequencies. If the proposed operating frequency is too low, the VT may not have enough Crt in order to provide enough feedback to sustain stable oscillations.
There are no foxes in atheistholes
www.dolphin-hsl.com
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.08054 seconds (72.33% PHP - 27.67% MySQL) with 11 queries
