Thanks Tubelab,
That was kind of my intention. I think I would try the Local Feedback from Plate to Plate.
You say about 330K as a starting point? How would I go about calculating what that value represents.
I guess what I mean is from the plate of the 1625 to the Plate of the 6SL7 at idle there is a voltage potential difference of 180Volts.
This obviously changes as the current changes thru the two tubes. What numbers am I using to calculate? Am I feeding back voltage?
Do I need to calculate in Rp somehow?
