diyAudio Sponsor
Old 8th March 2009, 06:27 PM   #1
Default Power supply testing
Hi, I am building a guitar amp and was wondering if I can test functionality of the power supply without anything attached to it or will it need a load? The HT/B+ line it 480v to the power stage anodes if that's any help.
Thanks for any help!
Old 8th March 2009, 06:30 PM   #2
what would B+ rise to if no load is applied?
Is it a CRC type of PSU?
or an LCRC type?
The LCRC will rise to a very high B+, if there is no load.
Would that open circuit voltage be a problem for any of the capacitors?
regards Andrew T.
Old 8th March 2009, 06:37 PM   #3
Its an LCRC design but i'm not sure how to work out the voltage without a load. All my caps are ~600v and I have 4 el34's and 8 ecc83's. Do I work out the off-load voltage by looking at the currents drawn?
Old 8th March 2009, 07:35 PM   #4
athos56 is offline athos56  United States
athos56's Avatar
I was told one time that it was ok to read the voltage right off the bare transformer leads, and that the unloaded voltage would be a bit higher than normal. I am using some unknown transfromers in a project, I know around what they put out, but not exactly. I planned on building the circuit up until the first RC section. So only the C-LC sections. Then I'll work out where I'm at voltage wise. I think it should be ok to power up the PSU for limited periods as long as your caps are over rated a bit.
Old 8th March 2009, 07:40 PM   #5
Well my transformer HT is rated at 340V 0.8A under full ohmic load and 4.5% regulation and therefore 480V after a bridge rectifier. Should I expect around 550V or so off load do you think?
Old 8th March 2009, 07:52 PM   #6
athos56's Avatar
While I'm inclined to think that you won't have to worry about your 600v caps, I'd leave the definitive answer to some of the wiser people here.
Power supply current limit for testing kubeek Solid State 1 12th February 2009 09:57 AM
Way of testing a speakers power rating? Gorbee Multi-Way 4 25th August 2006 11:41 PM
Power Tranistor Testing argonrepublic Chip Amps 4 14th January 2006 08:39 AM
Testing a power amp AndrewT Solid State 8 13th August 2005 03:43 PM
Power supply performance testing? How To Zero Cool Power Supplies 15 1st June 2005 01:25 PM
Page generated in 0.07882 seconds (77.16% PHP - 22.84% MySQL) with 10 queries
