Tube bias testers, your opinions, please.
Old 8th March 2009, 10:49 PM   #11
Nihilist is offline Nihilist  United States
If I place a 1 ohm resistor between my cathode and ground, this is parallelling the cathode bias resistor, which is NOT what I want to do. What am I missing here ?
I don't want to run A/B. I was under the impression that when running a single cathode bias resistor without a bypass cap (differential) that you MUST run class A , or that the amp will have major distortion when it goes into B.
Would it help to see a schematic ?
http://img101.imageshack.us/img101/5...9aarevizj4.png
........................Blake
Keep it simple
My Page Of SV1000 and DIY Stereo Links
Old 8th March 2009, 11:10 PM   #12
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
If you have cathode bias, no need to add a resistor - just measure across the one that's there. I = V/R
Old 8th March 2009, 11:38 PM   #13
OK, that's what I previously thought. Sometimes I get a little turned around with all the different options. . . .
So I have 60Ma across my Cathode resistor, according to Ohms law. So that is 30 Ma per tube, or 11.25W give or take.
For a triode tied 6P6S , this is about 85% of Max power at the Anode (13.2W).
For my situation using differential bias on the outputs , should I bias it up higher, closer to the theoretical max ?
What is the practical upper limit , 90% , 95% of Anode Max ?
Keep it simple
Old 9th March 2009, 06:37 PM   #14
Hi_Q is offline Hi_Q  England
Hi_Q's Avatar
I made my own unit-
http://homepage.ntlworld.com/lez/YAQ...er%20pic_1.JPG
http://homepage.ntlworld.com/lez/YAQ...%20checker.TIF
Although intended to check out my Yaqin EL34 amplifer, it has been very useful for matching up tubes in guitar amplifiers such as Marshall's.
I have been experimenting, with some success, a 100/120Hz low pass filter for feeding an oscilloscope. It enables one to crank up the scopes gain without noise issues and observe the ripple on the amplifiers output. After setting the correct bias on both PP output valves, although the ripple is so low, the filter enables one to fine tweak the bias on one tube for minimum ripple.
Tube bias testers, your opinions, please.Hide this!Advertise here!
Tube testers which is the best? Burnedfingers Equipment & Tools 105 19th April 2017 06:01 PM
Vacuum tube modeling software - beta testers wanted andrei Tubes / Valves 135 27th May 2015 09:41 PM
jackson tube testers dcb50 Swap Meet 0 2nd October 2008 05:18 PM
Best Tube Testers? Zap Tubes / Valves 10 6th March 2008 05:48 PM
Eico Tube Testers for sale. Coulomb Swap Meet 14 11th March 2005 11:56 PM
Copyright ©1999-2017 diyAudio
