diyAudio Sponsor
Old 8th March 2009, 04:01 PM   #11
I want to drive an old Beovox S35 loudspeaker, one for each channel. These are 8ohm speakers with a load of 35 watt.
Here are the specifications.
Beovox S35 specs
I think it should work although the volume isn't going to be very loud.
I am using this "project" also to get familiar with amplifiers and loudspeakers, my knowledge isn't very broad on this subject so please correct me when i am doing wrong things or make misconceptions about the theory.
Old 8th March 2009, 04:57 PM   #12
kevinkr's Avatar
Beovox S35 specs
The one critical bit of information missing is the efficiency of that speaker in dBSpl/W/M.. I suspect in this design that would probably in the low to mid 80's, but there is really no way to know. (This isn't very efficient, but should be adequate if levels are not expect to be very high.)
For somewhat more money an SE based on the EL34 would give you at least twice the power of an EL84 in SE (whether triode, UL or Pentode mode) and I suspect with these speakers you need the additional power.
www.kta-hifi.net
Old 8th March 2009, 05:10 PM   #13
I have been looking for the dBSpl/W/M values on the internet for almost two hours, nothing found....
If the EL84 design isn't powerful enough then iŽll buy other speakers with higher sensitivity. My current speakers are oldies and are first on my "kick list". So that's not really a problem.
( and i think my neighbors wonŽt mind the lesser volume ;-) )
6C33B-C push pull with output transformer vincent_brient Tubes / Valves 20 5th June 2009 06:49 PM
laying out dual output push-pull transformer? zilog Power Supplies 0 2nd September 2008 08:50 PM
Output transformer push pull om kalsoum Tubes / Valves 7 7th May 2007 09:48 PM
Push Pull Output Transformer wiring problem cyl Tubes / Valves 8 25th April 2007 02:23 AM
Output Transformers for an EL84 Push-Pull Amp boneshaker Tubes / Valves 2 3rd August 2006 07:52 PM
Page generated in 0.07328 seconds (71.87% PHP - 28.13% MySQL) with 10 queries
