Want to build tube amp - diyAudio
Old 6th March 2009, 01:47 AM   #1
jmillerdoc's Avatar
Question Want to build tube amp
I am considering trying to build my own tube amp. Never built anything like an amp before. Very limited knowledge. Willing to apply myself and learn whatever it takes. Would like to build about a 25w stereo amp, high quality, preferably from a kit.
Any suggestions? Advice? Direction.
Might sound like I am biting off more than I can chew, but I am very diligent and never give up!
OK...blast me!
Jeff
Old 6th March 2009, 01:50 AM   #2
aardvarkash10's Avatar
Default why? What music? What speakers?
What source? What bank balance? What skills? Not being negative at all - go for your life! But hard to recommend if those minor details are unknown...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 6th March 2009, 02:48 AM   #3
boywonder's Avatar
What's the budget?
Old 6th March 2009, 02:53 AM   #4
^^^ agree, need a bit more information to make a suggestion. Just some advice too, 25watts in tube SE = difficult to dangerous, in tube PP = easier but can be complicated. Read up very closely on tube safety, tube can be dangerous or deadly! Otherwise, as long as you are diligent, cool headed, persistent, and don't mind reading, you have come to the right place.
BTW keep cost in mind too, as you add watts to a tube amp, you add dollar signs quick, even more so than with solid state.
Cheers
James
Old 6th March 2009, 04:02 AM   #5
Jeff,
A 30 WPC "integrated" amp is easy enough. Build an "El Cheapo Grande". A short distance down the page you will find this thread. Another fellow wants to build his 1st amp and he's interested in "El Cheapo". An ECG uses the same 12AT7 based splitter/driver, a "taller" B+ rail, and 7591 O/P tubes.
Eli D.
Old 6th March 2009, 07:19 PM   #6
grhughes's Avatar
Default Look for a 6V6GT based design......
I think there is one on the Web called the Music Machine. Buy good trannys like Magnequest or Sowter.
" Polarities are seldom aware of their polarness." Prospero
Old 6th March 2009, 08:46 PM   #7
boywonder's Avatar
Poinz' 6V6 music machine is triode wired for 6-7 watts, and his EL34 version is triode wired for 16 watts.
What about an ST-70 dynaclone?
Available as a kit, parts, or scrounge for iron and scratch build.
Here is a link for a Dynaclone ST-70 kit:
http://store.triodestore.com/dynacoupgrades.html
There are other variations of these kits around also. Depending on your skill level, should be straightforward to build, and you can modify it later (triode, etc) for additional joy.
Want to Build my first Tube Amp samsagaz Tubes / Valves 6 9th November 2008 08:27 PM
1st Tube Amp - What to build? hifimaker Tubes / Valves 41 15th October 2008 02:33 AM
Help me build a tube TL? SamV Subwoofers 6 9th February 2008 01:43 AM
Looking to build a tube amp. Binaural Tubes / Valves 3 24th March 2006 04:18 PM
Copyright 1999-2017 diyAudio
