Back to back transformers.
Old 5th March 2009, 02:19 PM   #1
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Default Back to back transformers.
I know this has been discussed many times but I can't find the threads I remember in a search.
On the topic of using back to back transformers for HV supplies (say 120VAC:12VAC wired to a 12VAC:120VAC), I am trying to remember all the aspects of getting it right.
The one I remember is that the transformer hooked up to the mains should have a larger VA rating to accomodate it's own mag current plus the draw from the other transformer.
The one I can't remember is the caveat about dissimilar voltage ratings or ratios (i.e. a 120VAC:12VAC transformer feeding a 6VAC or 9VAC:120VAC transformer). What's the "gotcha" for that situation?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 5th March 2009, 02:37 PM   #2
ErikdeBest is offline ErikdeBest  Switzerland
The problem of feeding 12V to a 6 or 9V winding is that you will be overloading the second transformer... too high a magnetization flux (?).
Conversely, if you feed the 12V to a 15V winding you will be 'undermagnetizing' the second core...you can do it, but you should derate the VA rating of the second transformer.
And now some EE can come and explain it over again
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 5th March 2009, 05:55 PM   #3
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
Default not an EE but...
watchouts for me would be: in either case you are going ot have losses - so two identical transformers back to back will not produce the same output as input. THe loss factor depends on the transformer design and quality, but I would imagine up to 30% end to end.
Your second situation implies that your output winding is going to be at a higher voltage than it was designed for. Question here is will the insulation hold out? Otherwise, as above applies - and look to stay withing the original the VA rating, which means your current output will be lower than original spec (cos the voltage is higher...) MTCW.
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Back to back transformers.Hide this!Advertise here!
Back to Back transformers dsavitsk Tubes / Valves 5 20th August 2009 11:53 PM
Back to Back transformers and safety ground dsavitsk Tubes / Valves 1 9th February 2009 10:10 PM
back to back isolation transformers: maxlorenz Parts 30 27th March 2006 03:15 AM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
Back to Back transformers to get +B of 200V ?? Shoog Tubes / Valves 5 23rd September 2005 03:58 AM
Copyright ©1999-2017 diyAudio
