| diyAudio Sponsor | ||
How do I get 300v for the B+ from a battery ? I know the first radio's were powered by battery but not sure how they stepped it up.
Thanks Mark |
#2 |
They used vibrator circuits and batteries connected in series.
#4 |
Thanks,
That's pretty ingenuous. Definitely not something we would use today to run our amp's "off the grid" though. |
#5 |
Nowadays you use switched DC/DC-converters instead
Brgds Lars |
#6 |
Mark,
In the very early days of radio, there were "B" batteries made for the purpose of supplying B+ to the high tension circuits. These batteries were made by series many smaller voltage cells inside a single "B" battery package. Tube type car radios produced their B+ by using electromagnetic vibrators to switch the 12V dc on and off alternately to the primary side of a transformer. The stepped up secondary side of the transformer was then rectified and filtered to a smoothed DC at the high voltage level. If you are wanting to make high voltage DC today from a lower level DC battery voltage (e.g. 12V dc to 300 vdc), a boost dc inverter topology power supply is likely the best approach. A number of manufactures make IC specific for this purpose. DMSpike |
#7 |
Does anyone know what the waveform was like for these vibrator circuits?
I have two huge APS battery packs that have 4 12v/7ah batteries in them to produce 54Vdc output. They have built in autochargers and all. Of course I could just put them in series to create 108v B+ but this is worth looking into for a preamp or phono amp. |
#8 | |
I was wanting to generate a very clean 300 B+ from 12v I will look at using an inverter. They look fairly simple to implement. Mark |
#9 |
hey-Hey!!!,
Get an HEV pack. Ford Escape or Toy Prius have similar voltage and capacity. cheers, Douglas
the Tnuctipun will return |
#10 | |
The vibrator (essentially an oscillating relay with a set of contacts intent on creating a polarised voltage found itself in car radios with a notorious short life. Interference was a real bewildering problem. The tubes with a single heater wire as cathode were easy to destroy. Anyone remember all this ?? richy |
| Battery Charger for 15V Li-ION Battery Pack ??? | Jan Dupont | Parts | 2 | 11th April 2009 03:18 PM |
| Tubes power supply 220 t0 300V ? | wrangler | Tubes / Valves | 2 | 3rd September 2006 03:36 PM |
| TL431: Can it regulate 300V DC? | Danko | Power Supplies | 11 | 26th September 2005 11:45 AM |
| Battery | VoLCoM | Parts | 1 | 17th August 2003 09:45 AM |
| 300V PSU for 6sn7 tube output stage in dac | PTSOUNDLAB | Tubes / Valves | 0 | 17th June 2003 09:07 AM |
| Page generated in 0.11633 seconds (76.23% PHP - 23.77% MySQL) with 11 queries |
