| diyAudio Sponsor | ||
I am starting to build an all-tube microphone preamp. Planning to use two stages of 12AX7 and one 6922 SRPP output, now I am looking for the input and output transformers. Edcor looks to have what I need, but their web site does not a lot of information. Any suggestions on which Edcor transformer will work better?
Thx. |
#2 |
I've never used Edcor transformers. I checked out their web page and looked at their mic input transformers, specifically their 1:8 ratio ones as that's the kind of ratio you need for a tube mic pre.
I note that: 1. Specs do not define the operating level at which measurements are made 2. There is no magnetic screening 3. They are quite inexpensive I have no proof but I expect these are relatively poor mic transformers. You would probably be better looking at Jensen for example or Lunfdahl or Sowter. Cheers ian
Ian |
#3 |
Whichever transformers you choose, make sure that they will work well into the rather heavy capacitive load presented by your chosen 12AX7 input tube.
The Edcor plots I saw did specify the level. The left hand axis was marked "dBU." Distortion looked pretty good.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#4 |
FWIW I was not that happy with the sonics of the Edcor interstage that I tried. It could have been misapplication, I'm not a valve guy.
Pain is never permanent |
#5 |
Was that the one you used in your ST-70?
#6 |
Yes that was my hybrid experiment, Walt Jung's AD823/AD815 line stage directly driving an ST70 output stage with no global FB via a step-up interstage. Didn't really rock my boat.
#7 | |
Cheers Ian
Ian |
| edcor output transformer advice | nhuwar | Tubes / Valves | 3 | 9th November 2008 11:48 PM |
| Question about Edcor output transformer | Captain archer | Tubes / Valves | 8 | 28th June 2008 11:31 PM |
| Edcor Power Transformer | rudy129 | Swap Meet | 0 | 5th December 2007 02:49 PM |
| Suggestion on the input transformer for tube preamp | bee696 | Tubes / Valves | 3 | 2nd August 2006 05:43 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 05:36 AM |
| Page generated in 0.08256 seconds (75.08% PHP - 24.92% MySQL) with 10 queries |
