diyAudio Sponsor
Old 4th March 2009, 07:41 AM   #1
Bitrex is offline Bitrex  United States
Default Question about Allied & Hammond Power Transformer Ratings
I'm wondering how Allied & Hammond rate their power transformers maximum current output - are the current maximums shown for both sides of the secondaries under load, or is that the maximum current that can be drawn in the standard center tapped arrangement where only one side of the transformer is under load at a time?
Old 5th March 2009, 01:50 AM   #2
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
The transformer current rating is AC, from 1 end of the secondary winding to the other (not to center tap). The permisable average DC current draw is about equal to the AC rating, when using the standard full wave rectifier with capacitor input(centertap grounded, 2 diode config).
If your using bridge rectification (four diodes), the permissable DC current draw will be between .5 to .7 that of the transformers rating. However, your DC output voltage will be aprox. twice that of a full wave rectified.
read this
http://www.hammondmfg.com/pdf/5c007.pdf
I also recomend downloading PSUD2 for simulating power supplies. It's more accurate than the generalities I mentioned above.
Old 6th March 2009, 08:31 AM   #3
pmillett's Avatar
On the Allied and Hammond plate transformers, the HV secondaries are actually rated in DC mA using a full-wave rectifier (not bridge) and a cap-input filter.
You can a bit draw less current if using a bridge (I guess .5x to .7x is reasonable), and more using a choke-input filter.
Pete
When life hands you a jeffery, stroke the furry wall.
Hammond PT power ratings dsavitsk Tubes / Valves 4 23rd August 2009 09:23 PM
Allied 6K7VG Power Transformer For Sale nikolas812 Swap Meet 2 5th June 2009 11:53 PM
Output transformer current and power ratings boywonder Tubes / Valves 3 29th April 2009 10:00 PM
Question about current ratings of Hammond 300 series power transformers. G Tubes / Valves 14 4th April 2009 06:38 AM
Power supply transformer ratings deskmate88 Chip Amps 4 29th January 2004 06:29 AM
Page generated in 0.07604 seconds (66.27% PHP - 33.73% MySQL) with 10 queries
