diyAudio Sponsor
Old 19th April 2003, 07:43 AM   #1
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Default Leak TL12 replica using 807s?
I am thinking of building a stereo version of the Leak TL12, but using 807s instead of the triode-connected KT66, and 6SN7 instead of ECC33.
I have a couple of fire-engine red Mullard EF37A lying around, and some output transformers that should be ok.
Would this work, or would I be running the 807s too hard? Would I be better off connecting the outputs as ultralinear instead of triode?
Schematic
here
Anyone have experience with this amp? It seems to have a very good reputation! Thanks.
Old 19th April 2003, 12:37 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Go for it!
I believe that Langford-Smith (He of RDH4) got away with making a Williamson using triode-strapped 807 instead of triode-strapped KT66, and the output stage conditions are virtually identical, so you should be OK. If you leave a little room around the output valves, you could always change later to KT66 if it proves necessary.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 19th April 2003, 04:14 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Default GREEN LIGHT TOO.
Actually I've done this kind of work on a few Leaks already years ago.
While I left the input tubes in place (they last forever anyway) I changed the sockets of the KTs to UX5s and put in 807s in triode mode.
Worked straight away and sounded fine too us.
Frank
Old 19th April 2003, 04:55 PM   #4
316a is offline 316a  England
316a's Avatar
Default 807
Another alternative would be the loctal based 5B/255M which was designed (I believe) as a 'miniature' 807 replacement . This does not require a topcap and is another cheapie . Topcapped version is the even cheaper 5B/254M or 20V filament versions (5B/258m?) can be had dirt cheap . Only disadvantage is that ITT/STC were the only manufacturer , the 807 is more widely available and therefore cheaper
316a
Audiomeca TT Replica Jean-Paul_2 Analogue Source 4 15th October 2008 11:22 PM
807s replacing 6L6GCs Pyre Tubes / Valves 17 25th June 2007 03:41 AM
Shuguang 807s? AD5GB Tubes / Valves 14 1st November 2006 07:06 AM
Leak TL12 + Tannoy 15" jkeny Everything Else 1 4th March 2006 04:08 PM
Kt66 Gec Replica jacquesF77 Tubes / Valves 12 12th March 2005 09:03 AM
Page generated in 0.07671 seconds (72.23% PHP - 27.77% MySQL) with 10 queries
