diyAudio Sponsor
Old 3rd March 2009, 02:51 PM   #1
WRyan is offline WRyan  United States
Default External Test Points
Hello,
I would like to install external bias test points on my amp. I am curious to know what these kind of connectors are called.
Also, does anyone have a suggestion concerning what kind of externally accessible pot I can use for bias adjustment? I have heard of thumb screw style pots... never seen them though.
Any suggestions would be greatly appreciated!
Thanks Everyone!!
Old 3rd March 2009, 03:33 PM   #2
Trout is offline Trout  United States
Trout's Avatar
Default Re: External Test Points
Originally posted by WRyan
Hello,
Thanks Everyone!!
How about this, The exact mouser part numbers,
Electronic Hardware TIP JACK BLACK
Mouser Part #: 530-105-0803-1
Electronic Hardware TIP JACK RED
Mouser Part #: 530-105-0802-1
As far as the pot used, I always use The Fender Style 10K pot in most of my amps.
You can get them at AES
Antique Electronic Supply
Old 3rd March 2009, 03:41 PM   #3
Thank you very much!!
Old 3rd March 2009, 05:42 PM   #4
they're also called 'banana' plugs, they're 4mm. make sure you buy fully insulated ones
Old 3rd March 2009, 06:26 PM   #5
boywonder's Avatar
You can also get panel mount "tip" jacks from Digikey, Mouser, etc. That are smaller than banana jacks; they are for the tips of multimeter probes.
Panel mount pots are also available with a screwdriver slot in a flush-mounted shaft for this application.
Old 3rd March 2009, 07:57 PM   #6
exposed 'tips' are not a good idea if it's anything above 48V (say a bias point for an 845). 4mm banana jacks are what's commonly used for multimeters
Old 3rd March 2009, 09:53 PM   #7
Trout's Avatar
Most of the multimeters " Probes " fit the tip jacks in the pictures above.
The tip jacks from mouser (part number above) are pretty much the standard for bias test points on guitar amps these days.
There must be over a hundred of amplifier builders that use those exact parts.
The actual contact is well inside of the plastic mounting sleeve.
Old 3rd March 2009, 10:02 PM   #8
yes, we agree
i was just making a point about exposed banana plugs as they come in many different shapes, some not suitable for this purpose
Bring test points to chassis - Tubelab wicked1 Tubes / Valves 5 5th May 2008 01:53 AM
op-points for 27 pre...? JandG Tubes / Valves 0 1st June 2007 01:24 PM
crossover points ddoyle Multi-Way 1 16th December 2006 09:33 PM
4 points lt cdr data Solid State 0 20th June 2006 10:44 PM
Test points in Aleph P1.7 bbakota2000 Pass Labs 1 22nd June 2004 07:00 PM
Page generated in 0.09290 seconds (77.22% PHP - 22.78% MySQL) with 10 queries
