| diyAudio Sponsor | ||
this what my scope shows when i connect a 10khz squarewave @200mv in the input of my preamplifier
do you think that this correct ???? should i post a schematic of the preamp ????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
here is the schematic with what i am working with
your opinion about corners is getting rounded is because of oscillation ????
#4 |
very quick posting
#5 |
No, the rounding of the square wave is normal- it means that your bandwidth doesn't go to RF. It's the fuzzy tops and bottoms that show the oscillation.
edit: if you really have a 100k resistor at the input, that's what's causing the HF rolloff. But really, do you need half a megahertz bandwidth?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
Here's the same 10Khz square wave from my hyperfly preamp with -3dB 100Khz using EF184's as triodes. Tone controls flat. The EF184 is my tube of the month.
I will do anything to avoid using the 12AU7 series unless there is a darned good reason for doing so. richy |
#7 |
a lot of effort we come up with this design that lloks tha performs very fine for at least 20 KHZ square wave
any opinion will be very welcome thank you very much
#8 |
it seems that i had some error in my schematic ....
here is the correct one
#9 |
...or you are close to an AC EMI field like flouriescent lites. Cascading two sections doubles the transconductance and halves the plate resistance. Ray
"The gift of imagination is the gift of the gods imparted to a few for which they receive innumerable kicks in the a$$ their entire life." Le Corbusier (Edward Jenneret) |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
| Page generated in 0.08519 seconds (78.08% PHP - 21.92% MySQL) with 11 queries |
