| diyAudio Sponsor | ||
Aikido All in One line stage amp kit came out. Any thoughts on it or has anyone built it yet?
#2 |
Looks interesting and very tempting.
I wonder if there will be an octal version? |
#3 |
has anybody built this?
seems that the kits and pcb's are out of stock do you know where i can get one?
"I don't remember fighting Godzilla, but that's probably what I would've done" |
#4 | |
But why should it be very different from his other options, which are very popular But hard to imagine they would be better But we know that different supply may make a significant differense Im sure it wont be long before Broskie have them stocked again |
#5 |
Nice idea JB.
#6 |
Slightly better or slightly worse than the original Aikido, the point of is that it's easy - all in one!
For a newstarter in valve preamps, that's the important point. And this all-in-one Aikido certainly has a selling point Indeed very well done! I am looking forward to this.
#7 |
I hate to bump an old thread, but since I have a question on it...might as well.
Has anyone built one of these (specifically thinking the octal version)? I noticed there's a bunch of parts that can be ordered with the PCB...any advice in choosing which options? I'd like to go with metal-film resistors, and I assume the most expensive caps (RTI) offered are worth it? Thanks in advance
Jim J. Last edited by Glowbug; 5th September 2009 at 06:23 AM. |
#8 |
Glowbug,
I am seriously considering the Aikido octal all-in-one kit complete with Russian-made Tung-Sol 6SN7 tubes, RTI coupling caps, metal film resistors and selector switch. This is a bargain and takes a lot of the guesswork out for assembling a decent power supply for the octal amp configuration. I would also recommend Vampire CM1F RCA connectors and a decent SMD stepped attenuator that can be purchased via eBay.
Rich |
#9 |
Hi Glowbug, rhing,
I'm using the old Aikido Octal version (not all in one because I purchased it 2 years ago) with Russian made Tungsol 6SN7 and very pleased with it. Had I purchased it now I would go for all in one version because it saves a lot of time and effort in trying to collect parts and build yourself a PSU especially if you are a newbie. I think you can choose metal film for lowest noise and RTI cap is a good option If you want even better sound but with a higher cost (of course |
#10 |
I am trying to decide between the All-in-one or the Dual Mono Octal Aikido kit. Is there a sonic difference between the All-in-one vs Dual Mono if I use just ONE PSU for BOTH channels?
How will the sound improve having separate regulators for EACH channel with the Dual Mono kit? Channel separation, clarity, dynamics - not sure?... Do I need another power transformer too?... Proposed Power Supply: -Hammond 270BX -Mullard/RCA 5U4-GB -CLCLCRC: 20uF, 20H (Hammond 193C), 50uF, 10H (Hammond 158M), 50uF, 300R, 50uF. All PSU caps are 440V ASC Motor Run Capacitors. Thanks Last edited by 88man; 16th October 2009 at 02:05 AM. |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 09:50 PM |
| Aikido Line Stage | Bengali | Tubes / Valves | 6 | 10th September 2007 10:51 AM |
| Improving the Aikido line stage... | Bas Horneman | Tubes / Valves | 144 | 10th February 2006 04:00 AM |
| Page generated in 0.09051 seconds (81.20% PHP - 18.80% MySQL) with 11 queries |
