SS power supply. - Page 2 - diyAudio
Old 6th March 2009, 05:03 AM   #11
Originally posted by ray_moth
I like hybrid bridges but prefer TV dampers as the tube diodes, to get the least voltage drop - and they're quiet in operation and cheap!
Hi Ray ,
Correct , correct and correct . I agree entirely , with you.
Damper tubes can make an excellent and reliable power supply .
I can recommend :
6BY5GA ( double ) , 6AU4 and 6DE4 - about 170 mA
6AX4 and 6AX5 - about 120 mA
Regards ,
Carlos
Old 7th March 2009, 05:05 AM   #12
OOOps . Sorry .
6AX5 is a normal rectifier , not a TV damper.
The rest is correct !!
Carlos
Old 7th March 2009, 06:19 PM   #13
I've used only the 6D22S, which I could certainly recommend, but which does have a top cap for the cathode connection and uses the rare magnoval base.
I know there are TV dampers that don't have a top cap but I don't know enough about them to know which ones to recommend. I'm sure other people here can answer that.
Originally posted by refference
Hi Ray ,
I can recommend :
Regards ,
Carlos
Thanks guys. I`ve picked up a couple of 6cj3s to work with and will probably build a ss bridge followed by a 6cj3 to give me a slow soft start and lower the voltage a touch.
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 24th April 2011 12:48 AM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 05:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
Copyright 1999-2017 diyAudio
