| diyAudio Sponsor | ||
Has anyone tried making a parafeed amp using a non-polarized electrolytic for the parafeed cap? This is for a guitar amp so I am not concerned about distortion. I assume it will work as long as the cap is rated for twice B+ and there is some NFB for stability? Can it be pushed so far as to use roll-your-own NP's (2 'lytics back-to-back with protection diodes)? TIA
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
Presume you mean between anode and o/p transformer.
I would have assumed voltage rating only needed to exceed anode voltage + max signal swing. No need for nfb or anything else as far as a simple parafeed cap is concerned. (Although you might need nfb for other aspects of the amp I supose). If the inductance of the o/p transformer is highish then cap capacitance value need not be great; just a few micro-Farads. Watch out for ripple-current rating though. Roll-your-own + diodes?!?!? I have no idea... but why bother when off-the-shelf items are cheap-as-chips! Good luck. |
#3 |
Excuse me, but why don't you use an ordinary polarized electrolytic cap?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 | ||||
#5 |
I wouldn't recommend it. I've done some radical recaps (all caps) of guitar amps, using some very high quality caps (no electrolytics). All the players were very pleased with the results.
Guitar amps are a different animal than audio amps. You purposely build in clipping and distortion, so you'd think you could use lesser quality components in them. A bud (he designs custom amps both audio and guitar) and I were discussing this the other day. The gist of the discussion was, anything that sounds good in an audio amp, sounds good in a guitar amp. The quality of a parafeed cap is VERY important to the tone of a parafeed amp. I'm afraid a crappy cap will sound like a crappy cap in a guitar or audio amp, ESPECIALLY as a parafeed cap. twystd |
#6 | |
The hifi amps use film caps as they sound better, and at the point that you have put $1000 in to your amp, a $20 film cap instead of a $2 electrolytic is incidental. Generally, in parafeed, one side of the cap connects to the plate and the other to the transformer primary with the other side of the primary connected to ground or the cathode. Thus, the + side connects to the plate. You'll also see the transformer connected to the plate with the cap between the other primary lead and either ground or the cathode. In this case, the - side connects to the cathode or ground.
http://www.ecpaudio.com |
#7 | ||
#8 | |||
Polarised caps have often been used at amp outputs and seem fine when they have a polarising voltage across them. Quote:
#9 |
frugal-phile(tm)
Just use a film cap... we are tyalking less than 10 uF (we have 3.3 uF on our parafeed amps)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 | ||
The parafeed cap is very much more in the signal path than the power supply caps. The parafeed cap goes either between the plate and transformer primary, or the transformer primary and ground, therefore directly in the signal path. In a parafeed amp, the power supply cap is somewhat isolated from the signal coming from the plate by the plate choke, or even more so if you use a CCS instead of a choke. Some feel that parafeed isolates the power supply, and the power supply caps are not important. I don't agree with that from direct experience with trying different caps on the bread board, and hearing a distinct difference, but less so than in conventional single ended designs. In the case of conventional single ended designs I do agree the last power supply cap is directly in the signal path. Besides, IMO electrolytics don't sound good in power supplies, and I don't use them there either. As a matter of fact I avoid electrolytics whenever possible. Of course everybody has an opinion and you're certainly welcome to yours. twystd |
| 2a3 parafeed | alexg | Tubes / Valves | 2 | 17th November 2007 10:47 AM |
| to parafeed or not to parafeed that is the question | nhuwar | Tubes / Valves | 63 | 28th February 2007 12:29 PM |
| OTL or parafeed? | Jaime | Tubes / Valves | 14 | 11th December 2005 07:22 AM |
| 6V6 Parafeed? | G | Tubes / Valves | 13 | 8th June 2004 01:05 PM |
| Parafeed | Brett | Tubes / Valves | 14 | 7th April 2003 12:53 PM |
| Page generated in 0.12872 seconds (91.57% PHP - 8.43% MySQL) with 10 queries |
